MantisBT - ParaView | |||||
View Issue Details | |||||
0011415 | ParaView | Bug | public | 2010-11-08 11:19 | 2010-12-16 18:15 |
Reporter | Stephane P | ||||
Assigned To | Berk Geveci | ||||
Priority | normal | Severity | minor | Reproducibility | always |
Status | closed | Resolution | fixed | ||
Product Version | Development | ||||
Project | ParaViS | ||||
Topic Name | |||||
Type | |||||
Summary | 0011415: surface of quadratic cells in multiblock is extracted before applying slice | ||||
Description | When loading a multibloc data composed of quadratic cells (VTK_QUADRATIC_TETRA in this case, but it is visible for other non-linear types), applying the slice filter produces the slice of the skin of the object, not the slice of the interior of the cells as it should. It is as if an intermediate "Extract surface" filter was added between the input filter and the slice filter. | ||||
Steps To Reproduce | |||||
Additional Information | To reproduce the bug : *load the tetra10.vtk attached file *apply the "Group Datasets" filter to create a multibloc dataset composed of only this quadratic tetra *apply the slice filter --> only the edges of the triangle are displayed, instead of the filled triangle. | ||||
Relationships | |||||
Attached Files | tetra10.vtk (325) 2010-11-08 11:19 https://www.vtk.org/Bug/file/8479/tetra10.vtk | ||||
Issue History | |||||
2010-11-08 11:19 | Stephane P | New Issue | |||
2010-11-08 11:19 | Stephane P | File Added: tetra10.vtk | |||
2010-11-08 11:31 | Stephane P | Note Added: 0023062 | |||
2010-11-08 14:10 | Utkarsh Ayachit | Status | backlog => tabled | ||
2010-11-08 14:10 | Utkarsh Ayachit | Assigned To | => Berk Geveci | ||
2010-12-16 10:24 | Berk Geveci | Note Added: 0024209 | |||
2010-12-16 10:24 | Berk Geveci | Status | tabled => @80@ | ||
2010-12-16 10:24 | Berk Geveci | Resolution | open => fixed | ||
2010-12-16 17:18 | Berk Geveci | Note Added: 0024221 | |||
2010-12-16 18:14 | Alan Scott | Note Added: 0024223 | |||
2010-12-16 18:14 | Alan Scott | Status | @80@ => closed | ||
2011-06-23 11:44 | Utkarsh Ayachit | Project | => ParaViS |
Notes | |||||
