MantisBT - ParaView | |||||
View Issue Details | |||||
0011637 | ParaView | Bug | public | 2010-12-21 21:48 | 2011-01-20 22:22 |
Reporter | Alan Scott | ||||
Assigned To | Robert Maynard | ||||
Priority | high | Severity | major | Reproducibility | always |
Status | closed | Resolution | fixed | ||
Product Version | |||||
Target Version | Fixed in Version | 3.10 | |||
Project | |||||
Topic Name | |||||
Type | |||||
Summary | 0011637: Particles don't show up multi file | ||||
Description | I have a dataset that has particles show up when you open one file, but not multiple files. This dataset read correctly in PV 3.6.2, but has not worked since then. To see what it should look like: * ParaView local server, Linux client (anything will do), trunk. * Open particles.exo. All variables on. In blocks, turn on ParticleBlock ONLY. Apply. * Filters/ Warp By Vector. Take defaults (Coords_, and 1). Apply. * You should see lots of points. (As a cool simulation, turn Sets surface_4 on. then, color the points by Radius.) To see the problem, open dataset paralan.e-s0003-2.[0-1]. This is just the datset above, plus another one. Repeat directions above, notice that you don't see anything. Also, compare the Information tab from both readers (single file and multiple file). With single, you have the same number of points as cells, with two files, you have lots of cells but one point. If possible, this is very high priority for 3.10.0 (but not a show stopper.) Ask me for the file (data/alex.../particles tar file) | ||||
Steps To Reproduce | |||||
Relationships | |||||
Attached Files | |||||
Issue History | |||||
2010-12-21 21:48 | Alan Scott | New Issue | |||
2011-01-06 09:30 | Robert Maynard | Assigned To | => Robert Maynard | ||
2011-01-06 09:30 | Robert Maynard | Status | backlog => tabled | ||
2011-01-18 11:19 | Robert Maynard | Note Added: 0024864 | |||
2011-01-18 11:19 | Robert Maynard | Status | tabled => @80@ | ||
2011-01-18 11:19 | Robert Maynard | Fixed in Version | => 3.10 | ||
2011-01-18 11:19 | Robert Maynard | Resolution | open => fixed | ||
2011-01-20 22:22 | Alan Scott | Note Added: 0024984 | |||
2011-01-20 22:22 | Alan Scott | Status | @80@ => closed |
Notes | |||||
