MantisBT - ParaView | |||||
View Issue Details | |||||
0011941 | ParaView | Bug | public | 2011-03-08 12:58 | 2011-04-05 17:17 |
Reporter | Paul Edwards | ||||
Priority | normal | Severity | minor | Reproducibility | always |
Status | closed | Resolution | fixed | ||
Platform | Linux | OS | Ubuntu | OS Version | 10.04 |
Product Version | Development | ||||
Target Version | Fixed in Version | 3.12 | |||
Project | |||||
Topic Name | |||||
Type | |||||
Summary | 0011941: Bug with selection in chart view | ||||
Description | If you select an area in the line chart view that does not contain any points it causes a segfault. | ||||
Steps To Reproduce | 1) Create Wavelet 2) Extract Surface 3) Plot On Intersection Curves 4) Drag middle mouse button around a region that doesn't have any points | ||||
Additional Information | patch to fix: diff --git a/Qt/Core/pqContextView.cxx b/Qt/Core/pqContextView.cxx index db7fc09..a3356b5 100644 --- a/Qt/Core/pqContextView.cxx +++ b/Qt/Core/pqContextView.cxx @@ -445,6 +445,10 @@ void pqContextView::selectionChanged() } vtkIdTypeArray *arr = vtkIdTypeArray::SafeDownCast(node->GetSelectionList()); + if (!arr) + { + return; + } ids.clear(); for (vtkIdType i = 0; i < arr->GetNumberOfTuples(); ++i) { | ||||
Relationships | |||||
Attached Files | |||||
Issue History | |||||
2011-03-08 12:58 | Paul Edwards | New Issue | |||
2011-03-08 13:01 | Paul Edwards | Note Added: 0025694 | |||
2011-04-01 11:20 | Utkarsh Ayachit | Note Added: 0026021 | |||
2011-04-01 11:20 | Utkarsh Ayachit | Status | backlog => @80@ | ||
2011-04-01 11:20 | Utkarsh Ayachit | Fixed in Version | => 3.12 | ||
2011-04-01 11:20 | Utkarsh Ayachit | Resolution | open => fixed | ||
2011-04-01 11:20 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit | ||
2011-04-05 17:17 | Alan Scott | Note Added: 0026102 | |||
2011-04-05 17:17 | Alan Scott | Status | @80@ => closed |
Notes | |||||
