MantisBT - ParaView | |||||
View Issue Details | |||||
0012136 | ParaView | Bug | public | 2011-04-29 13:46 | 2016-08-12 09:58 |
Reporter | Sven Buijssen | ||||
Priority | normal | Severity | minor | Reproducibility | always |
Product Version | 3.10.1 | ||||
Project | |||||
Topic Name | |||||
Type | |||||
Summary | 0012136: Clip/Slice plane widget reset reenabled having had lost focus | ||||
Description | PV 3.10.1 and development builds (PV commit b8eaf3cdd589e3ee5377cd7a8550554e406f5c47) exhibits the following issue: built-in server, --disable-registry command line option * Sources / Wavelet / Apply * Filters / Slice / Slice Type Plane / Z-Normal / Move plane widget beyond the bounds, e.g. to Origin 10.7;0;-10.7 / Apply * Disable "Show Plane" checkbox * Make Wavelet1 active object * Make Slice1 active object * Enable "Show Plane" checkbox => plane widget has been reset to X-Normal. additionally: clicking now on the Z-Normal button does not change the position of the widget, it remains normal to the X plane The same happens for the clip plane filter: * Sources / Wavelet / Apply * Filters / Clip / Clip Type Plane / Z-Normal / Move plane widget beyond the bounds, e.g. to Origin 0;0;-10.7 / Apply * Disable "Show Plane" checkbox * Make Wavelet1 active object * Make Clip1 active object * Enable "Show Plane" checkbox => plane widget has been reset to X-Normal. Tested with Ubuntu 10.04.2 LTS bit and Solaris SPARC 64 bit. Most likely related to, if not even a duplicate of http://www.paraview.org/Bug/view.php?id=9592 [^] | ||||
Steps To Reproduce | |||||
Relationships | |||||
Attached Files | |||||
Issue History | |||||
2011-04-29 13:46 | Sven Buijssen | New Issue | |||
2016-08-12 09:58 | Kitware Robot | Note Added: 0037967 | |||
2016-08-12 09:58 | Kitware Robot | Status | backlog => closed | ||
2016-08-12 09:58 | Kitware Robot | Resolution | open => moved | ||
Notes | |||||
