MantisBT - ParaView |
View Issue Details |
0012168 | ParaView | Bug | public | 2011-05-06 19:37 | 2011-08-17 20:28 |
Reporter | Alan Scott | |
Assigned To | Robert Maynard | |
Priority | normal | Severity | minor | Reproducibility | always |
Status | closed | Resolution | fixed | |
Product Version | | |
Target Version | 3.12 | Fixed in Version | 3.12 | |
Project | Sandia |
Topic Name | 12168-Cleanup-ResetCache-ExodusII |
Type | incorrect functionality |
Summary | 0012168: Cleanup ResetCache for Exodus reader |
Description | We need to understand and cleanup the Exodus reader ResetCache code. This code is problematic with ParaView, and when turned off, has been problematic with Pat at Sandia. We really should try to figure out what this code does, and turn it off in a way that doesn't hurt Pat. |
Steps To Reproduce | |
Additional Information | |
Tags | No tags attached. |
Relationships | related to | 0011982 | closed | Robert Maynard | 3.10.0 has a fatal memory leak |
Attached Files | |
2011-05-06 19:37 | Alan Scott | New Issue | |
2011-07-21 10:32 | Ken Moreland | Relationship added | related to 0011982 |
2011-07-21 10:35 | Ken Moreland | Note Added: 0027036 | |
2011-07-28 13:25 | Alan Scott | Project | => Sandia |
2011-07-28 13:25 | Alan Scott | Type | => incorrect functionality |
2011-07-28 13:25 | Alan Scott | Status | backlog => todo |
2011-07-28 14:06 | Alan Scott | Note Added: 0027093 | |
2011-07-28 14:07 | Alan Scott | Note Edited: 0027093 | bug_revision_view_page.php?bugnote_id=27093#r368 |
2011-07-28 14:54 | Ken Moreland | Note Added: 0027095 | |
2011-08-03 09:00 | Utkarsh Ayachit | Assigned To | => Robert Maynard |
2011-08-03 09:00 | Utkarsh Ayachit | Target Version | => 3.12 |
2011-08-03 09:04 | Robert Maynard | Status | todo => active development |
2011-08-03 13:51 | Robert Maynard | Note Added: 0027216 | |
2011-08-03 14:03 | Ken Moreland | Note Added: 0027217 | |
2011-08-04 11:32 | Robert Maynard | Note Added: 0027225 | |
2011-08-10 12:57 | Robert Maynard | Topic Name | => 12168-Cleanup-ResetCache-ExodusII |
2011-08-10 12:57 | Robert Maynard | Status | active development => gatekeeper review |
2011-08-10 12:57 | Robert Maynard | Fixed in Version | => 3.12 |
2011-08-10 12:57 | Robert Maynard | Resolution | open => fixed |
2011-08-11 15:11 | Robert Maynard | Note Added: 0027342 | |
2011-08-12 14:23 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2011-08-12 14:23 | Utkarsh Ayachit | Note Added: 0027351 | |
2011-08-17 20:28 | Alan Scott | Note Added: 0027386 | |
2011-08-17 20:28 | Alan Scott | Status | customer review => closed |
(0027036)
Ken Moreland
2011-07-21 10:35
Implicit in this bug is that we should not re-introduce the memory footprint problems of bug 0011982, which may happen if we simply blindly turn the cache back on. Before closing this bug it should be checked that 0011982 still cannot be replicated. |
(0027093)
Alan Scott
2011-07-28 14:06
(edited on: 2011-07-28 14:07) |
The other problem (reverse of Ken's note above) is that we have reintroduced bug number 0006770. In other words, reading of datasets with large numbers of blocks is slow.
Please use many.e to test. It has been pushed to the VTKLargeData repository.
(0027095)
Ken Moreland
2011-07-28 14:54
Also, please make a regression test that loads many.e so we don't reintroduce the problem yet again. |
(0027216)
Robert Maynard
2011-08-03 13:51
My Proposal is to do the following:
Allow vtkPExodusIIReader to specify a cache limit per MPI process and than divide that cache size equally among all vtkExodusIIReaders. We than expose the cache limit option as a GUI setting of the reader.
So if the user sets a cache of 1GB, and we have 10 readers per process each reader would have a cache size of 102.4MB |
(0027217)
Ken Moreland
2011-08-03 14:03
It was my understanding (and I may be wrong) that the cache is used mostly during the RequestData pass and is pretty useless after the fact. In some rare circumstances, like when the user adds or removes a block, the cached fields could be reused. But when something like the time step changes, all the caches become invalid anyway. I think that's why we weren't seeing a big effect when turning off the cache of single block, many time step files.
If that is the case, allow me to make a counter proposal. Rather than split the cache among the vtkExodusIIReaders, let only one have a cache at any one time. To do this, have the vtkExodusIIReader free its cache once it's finished reading its file (right before it returns from its own RequestData or whatever the execute method is called).
The vtkExodusIIReaders are run in sequential order, right? So the first one would be called. It would use all the allotted cache. It would read its file. It would free its cache. Then the next reader would be called which could again use all the cache.
This would have two advantages. Advantage 1: Every reader gets all the cache. Advantage 2: when vtkPExodusIIReader returns from RequestData, none of these caches are hanging around. |
(0027225)
Robert Maynard
2011-08-04 11:32
So after your comment Ken I went back to see how the cache is used. We are both right in essence the cache stores information based on the timestep, the issue is that alot of information like GLOBAL_ELEMENT_ID, GLOBAL_NODE_ID, ELEM_MAP, FACE_MAP are stored at timestep -1 as they are constant for all timesteps, while the NODAL_COORDS and properties are stored per time step that they change on, so if the NODAL_COORDS never change for the entire time range it will only have a single cache entry. |
(0027342)
Robert Maynard
2011-08-11 15:11
I have updated the code based on our discussion during the ParaView meeting. |
(0027351)
Utkarsh Ayachit
2011-08-12 14:23
(0027386)
Alan Scott
2011-08-17 20:28
I will accept this as good enough for now. I did observe the following behavior:
* many.e loaded within about 5 seconds. Excellent.
* Whipple shield had memory grow when I toggled variables on and off, by about 100 mbytes. However, it then became stable.
* Whipple shield had memory grow when I ran through all timesteps by about 300 mbytes. Upon returning to timestep 0, this memory growth did not go away (thus, I assume it is caching). However, after about 5 or so timesteps, it stopped growing. Further, the next time i went through time, it did not grow.
Tested Linux, development, local server. |
