MantisBT - ParaView | |||||
View Issue Details | |||||
0012170 | ParaView | Bug | public | 2011-05-09 21:56 | 2016-08-12 09:58 |
Reporter | Alan Scott | ||||
Priority | normal | Severity | minor | Reproducibility | always |
Product Version | |||||
Project | Sandia | ||||
Topic Name | |||||
Type | |||||
Summary | 0012170: Precision problem with .vtp files | ||||
Description | I am finding really strange results when trying to visualize the following dataset. ParaView Trunk, local server, Windows (known to occur on Linux). Insert the following into a file called test.vtp. <?xml version="1.0"?> <VTKFile type="PolyData" version="0.1"> <PolyData> <Piece NumberOfPoints="3" NumberOfPolys="1"> <Points> <DataArray type="Float64" NumberOfComponents="3" format="ascii"> -7.5445544554e-02 -1.0048351648e-03 8.9374551773e+03 -7.3433663366e-02 -1.0048351648e-03 8.9374551773e+03 -7.3433663366e-02 1.0048351648e-03 8.9374551773e+03 </DataArray> </Points> <Polys> <DataArray type="Int32" Name="connectivity" format="ascii"> 0 1 2 </DataArray> <DataArray type="Int32" Name="offsets" format="ascii"> 3 </DataArray> </Polys> </Piece> </PolyData> </VTKFile> Now, open this data and rotate it. It will jitter, and jump all over the place. Assuming ParaView is using doubles internally, this should not happen. | ||||
Steps To Reproduce | |||||
Relationships | |||||
Attached Files | |||||
Issue History | |||||
2011-05-09 21:56 | Alan Scott | New Issue | |||
2011-09-01 10:56 | Utkarsh Ayachit | Project | => Sandia | ||
2016-07-13 21:02 | Alan Scott | Note Added: 0036443 | |||
2016-08-12 09:58 | Kitware Robot | Note Added: 0037972 | |||
2016-08-12 09:58 | Kitware Robot | Status | backlog => closed | ||
2016-08-12 09:58 | Kitware Robot | Resolution | open => moved | ||
Notes | |||||
