MantisBT - ParaView |
View Issue Details |
0012363 | ParaView | (No Category) | public | 2011-07-13 04:26 | 2012-02-08 17:24 |
Reporter | Sven Buijssen | |
Assigned To | Sankhesh Jhaveri | |
Status | closed | Resolution | fixed | |
Product Version | 3.10.1 | |
Target Version | | Fixed in Version | 3.12 | |
Project | TBD |
Topic Name | 12181-Writer-Failure |
Type | incorrect functionality |
Summary | 0012363: Saving as PVTI/PVTU fails if file name contains more than 1 dot |
Description | PV 3.10.1 official binary release and own build of git master as of now (with AutoMPI ON to be connected to at least 2 pvserver processes, otherwise saving as PVT? is not available):
Sources - Wavelet
File - Save Data - File name: "foo.bar.pvti"
=> ERROR: .../ParaViewCore/ServerManager/vtkSMWriterFactory.cxx, line 361
vtkSMWriterFactory (0x1420b30): No matching writer found.
Failed to create writer for: ".../foo.bar.pvti"
Use "foobar.pvti" as file name instead and everything works smoothly.
The same error occurs when trying to save to PVTU file format (squeeze in a "Filters - Clean to Grid" before trying to save). |
Steps To Reproduce | |
Additional Information | |
Tags | No tags attached. |
Relationships | related to | 0012181 | closed | Sankhesh Jhaveri | VTUWriter fails if filename contains multiple dots |
Attached Files | |
2011-07-13 04:26 | Sven Buijssen | New Issue | |
2011-09-02 12:59 | Utkarsh Ayachit | Assigned To | => Sankhesh Jhaveri |
2011-09-26 09:08 | Sankhesh Jhaveri | Topic Name | => 12181-Writer-Failure |
2011-09-26 09:08 | Sankhesh Jhaveri | Note Added: 0027524 | |
2011-09-26 09:08 | Sankhesh Jhaveri | Status | backlog => gatekeeper review |
2011-09-26 09:08 | Sankhesh Jhaveri | Resolution | open => fixed |
2011-09-26 09:16 | David Partyka | Relationship added | related to 0012181 |
2011-09-26 09:16 | David Partyka | Note Added: 0027525 | |
2011-09-26 09:16 | David Partyka | Status | gatekeeper review => customer review |
2011-11-11 17:08 | Utkarsh Ayachit | Fixed in Version | => 3.12 |
2012-02-08 17:24 | Utkarsh Ayachit | Status | customer review => closed |
2012-02-08 17:24 | Utkarsh Ayachit | Note Added: 0028142 | |
