MantisBT - ParaView | |||||
View Issue Details | |||||
0012563 | ParaView | (No Category) | public | 2011-08-31 14:53 | 2016-08-12 09:58 |
Reporter | Hal Canary | ||||
Product Version | 3.10.1 | ||||
Project | TBD | ||||
Topic Name | |||||
Type | usability | ||||
Summary | 0012563: parallel coordinates view interaction bugs | ||||
Description | Currently, in ParaView, a selection is created in parallel coordinates through mouse interaction. In order to reset the selection, an axis must be clicked without dragging. This is non-intuitive and easy to do by mistake. A "reset" button would be easier to use Because of how the selection mechanism works, it is only possible to select subsets of the current selection; it is never possible to add to the selection without resetting. This may make it difficult to modify a complex selection mechanism (i.e. one that involves limits on several axes). Axes may be re-ordered by right-clicking and dragging. When this happens, the user might expect the axes to be evenly spaced in the new order to make a pretty-looking chart. This does not happen. When axes are re-ordered and the selection is modified or reset, the new ordering is lost. This is not what I expect to happen. | ||||
Steps To Reproduce | |||||
Relationships | |||||
Attached Files | |||||
Issue History | |||||
2011-08-31 14:53 | Hal Canary | New Issue | |||
2016-08-12 09:58 | Kitware Robot | Note Added: 0038060 | |||
2016-08-12 09:58 | Kitware Robot | Status | backlog => closed | ||
2016-08-12 09:58 | Kitware Robot | Resolution | open => moved | ||
Notes | |||||
