MantisBT - ParaView | |||||
View Issue Details | |||||
0012577 | ParaView | (No Category) | public | 2011-09-07 07:44 | 2016-08-12 09:58 |
Reporter | Paul Edwards | ||||
Product Version | |||||
Project | TBD | ||||
Topic Name | |||||
Summary | 0012577: Parallel Coordinates bug with column visibility on selection | ||||
Description | The view will reset to showing all columns if you limit the number of columns to display using the "Display" tab in the "Object Inspector" and then select a range in the parallel co-ordinates view. | ||||
Steps To Reproduce | |||||
Relationships | |||||
Attached Files | |||||
Issue History | |||||
2011-09-07 07:44 | Paul Edwards | New Issue | |||
2016-08-12 09:58 | Kitware Robot | Note Added: 0038065 | |||
2016-08-12 09:58 | Kitware Robot | Status | backlog => closed | ||
2016-08-12 09:58 | Kitware Robot | Resolution | open => moved | ||
Notes | |||||
