MantisBT - ParaView
View Issue Details
0012579ParaView(No Category)public2011-09-07 11:232016-08-12 09:58
Paul Edwards
Kitware Robot
normalminorhave not tried
closedmoved
TBD
incorrect functionality
0012579: Line chart display bug when loading a statefile
The "Display" tab in the "Object Inspector" does not populate the "Use Data Array" combo box in the "X Axis Data" section when it is set up from a state file.
I've attached a script that generates a statefile (saves to /tmp/mystate.pvsm)
No tags attached.
? create-state.py (1,770) 2011-09-07 11:23
https://www.vtk.org/Bug/file/9020/create-state.py
Issue History
2011-09-07 11:23Paul EdwardsNew Issue
2011-09-07 11:23Paul EdwardsFile Added: create-state.py
2011-09-07 11:29Paul EdwardsNote Added: 0027460
2016-08-12 09:58Kitware RobotNote Added: 0038067
2016-08-12 09:58Kitware RobotStatusbacklog => closed
2016-08-12 09:58Kitware RobotResolutionopen => moved
2016-08-12 09:58Kitware RobotAssigned To => Kitware Robot
Notes
(0027460)
Paul Edwards
2011-09-07 11:29
Also, the combo box never gets updates when filters/sources earlier in the pipeline.
E.g. plot something created in the calculator, then rename the array name with the calculator - it stays the same in the display tab but will also give the error:
ERROR: In ParaView/VTK/Charts/vtkPlotPoints.cxx, line 635
vtkPlotLine (0x34e6010): No X column is set (index 0).
(0038067)
Kitware Robot
2016-08-12 09:58
Resolving issue as `moved`.
