MantisBT - ParaView |
View Issue Details |
0012652 | ParaView | (No Category) | public | 2011-10-13 11:29 | 2011-11-28 13:23 |
Reporter | Andy Bauer | |
Assigned To | Andy Bauer | |
Status | closed | Resolution | fixed | |
Product Version | git-master | |
Target Version | 3.12 | Fixed in Version | 3.12 | |
Project | TBD |
Topic Name | 12652-coprocessing-writers-fix |
Type | incorrect functionality |
Summary | 0012652: coprocessing writers menu is not enabled after creating a filter and hitting the Apply button |
Description | When a filter is created the Writers menu for coprocessing is disabled as it should be (similarly to other filters). When the Apply button is hit though the Writers menu should be enabled but it isn't (it is for the applicable filters). Steps to reproduce:
1. Load the coprocessing script generator plugin
2. Create a source -- note that the Writers menu is now disabled. It does get enabled though if the active source is changed.
This fix will also include changes such that plugin writers can be used and made available in the Writers menu. They will need to have a CoProcessing hint in their XML -- see the servermanager.xml file in the <ParaView>/Plugins/CoProcessingScriptGenerator/Resources/servermanager.xml |
Steps To Reproduce | |
Additional Information | |
Tags | No tags attached. |
Attached Files | |
2011-10-13 11:29 | Andy Bauer | New Issue | |
2011-10-13 11:29 | Andy Bauer | Assigned To | => Andy Bauer |
2011-10-13 11:45 | Andy Bauer | Status | backlog => todo |
2011-10-13 11:45 | Andy Bauer | Status | todo => active development |
2011-10-13 13:05 | Andy Bauer | Target Version | => 3.12 |
2011-10-13 13:06 | Andy Bauer | Topic Name | => 12652-coprocessing-writers-fix |
2011-10-13 13:06 | Andy Bauer | Note Added: 0027570 | |
2011-10-13 13:06 | Andy Bauer | Status | active development => gatekeeper review |
2011-10-13 13:06 | Andy Bauer | Fixed in Version | => git-next |
2011-10-13 13:06 | Andy Bauer | Resolution | open => fixed |
2011-10-14 16:00 | Utkarsh Ayachit | Note Added: 0027579 | |
2011-10-14 16:00 | Utkarsh Ayachit | Status | gatekeeper review => todo |
2011-10-24 11:37 | David Partyka | Status | todo => active development |
2011-10-24 11:38 | David Partyka | Status | active development => gatekeeper review |
2011-10-24 11:39 | David Partyka | Note Added: 0027602 | |
2011-10-24 11:39 | David Partyka | Status | gatekeeper review => customer review |
2011-11-11 17:08 | Utkarsh Ayachit | Fixed in Version | git-next => 3.12 |
2011-11-28 13:23 | Andy Bauer | Note Added: 0027737 | |
2011-11-28 13:23 | Andy Bauer | Status | customer review => closed |
