MantisBT - ParaView | |||||
View Issue Details | |||||
0012676 | ParaView | (No Category) | public | 2011-10-24 14:18 | 2016-08-12 09:59 |
Reporter | Orion Poplawski | ||||
Product Version | 3.10.1 | ||||
Project | TBD | ||||
Topic Name | |||||
Summary | 0012676: PV_FORWARD_PATH_INSTALL not set properly if PV_INSTALL_BIN_DIR and PV_INSTALL_LIB_DIR set | ||||
Description | For the Fedora MPI packages of paraview I need to install the binaries into /usr/lib{,64}/openmpi/bin and the libraries into /usr/lib{,64}/openmpi/lib/paraview which I do with: -DPV_INSTALL_BIN_DIR:PATH=%{_lib}/openmpi/bin \ -DPV_INSTALL_LIB_DIR:PATH=%{_lib}/openmpi/lib/paraview \ %{_lib} is set to lib/lib64 as needed. This results in: Error converting runtime path entry "/usr/lib64/openmpi/bin/../lib64/openmpi/lib/paraview" to real path: No such file or directory when trying to run pvserver. It seems that there are too many assumptions about shared paths in CMake/ParaViewMacros.cmake when constructing PV_FORWARD_PATH_INSTALL and it does not seem possible to override it. In this case PV_FORWARD_PATH_INSTALL would need to be either ../lib/paraview or ../../../lib64/openmpi/lib/paraview. | ||||
Steps To Reproduce | |||||
Relationships | |||||
Attached Files | |||||
Issue History | |||||
2011-10-24 14:18 | Orion Poplawski | New Issue | |||
2016-08-12 09:59 | Kitware Robot | Note Added: 0038091 | |||
Notes | |||||
