MantisBT - ParaView |
View Issue Details |
0012701 | ParaView | (No Category) | public | 2011-11-03 09:44 | 2012-02-08 17:24 |
Reporter | Sebastien Jourdain | |
Assigned To | Utkarsh Ayachit | |
Status | closed | Resolution | fixed | |
Product Version | | |
Target Version | | Fixed in Version | 3.14 | |
Project | TBD |
Topic Name | multi-clients-collaboration |
Type | incorrect functionality |
Summary | 0012701: Chart selection can became out of synch with collaboration |
Description | The test pvcs-collab.SpreadSheet2 can highlight this situation when the resulting image show a chart with no selection at all.
When this happen and you start interacting with the slave client that became master once the original master just left, you can notice the following.
- If you try to select a set of points on the chart, the only points that will get selected will be the one that were supposed to be selected at the first place when the master left.
- If you try to select a point from a spreadsheet view, nothing will change the selected points. At first, when none selected points are shown, none will be shown and once you interactively selected some through the chart view, only the one that get selected will remain. |
Steps To Reproduce | |
Additional Information | |
Tags | No tags attached. |
Attached Files | |
2011-11-03 09:44 | Sebastien Jourdain | New Issue | |
2011-11-03 09:44 | Sebastien Jourdain | Assigned To | => Utkarsh Ayachit |
2011-11-08 23:11 | Utkarsh Ayachit | Topic Name | => multi-clients-collaboration |
2011-11-08 23:11 | Utkarsh Ayachit | Note Added: 0027672 | |
2011-11-08 23:11 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
2011-11-08 23:11 | Utkarsh Ayachit | Fixed in Version | => git-next |
2011-11-08 23:11 | Utkarsh Ayachit | Resolution | open => fixed |
2011-11-18 14:53 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
2011-11-18 14:54 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2011-11-18 14:54 | Utkarsh Ayachit | Note Added: 0027710 | |
2012-02-08 17:21 | Utkarsh Ayachit | Fixed in Version | git-master => 3.14 |
2012-02-08 17:24 | Utkarsh Ayachit | Status | customer review => closed |
2012-02-08 17:24 | Utkarsh Ayachit | Note Added: 0028115 | |
