MantisBT - ParaView | |||||
View Issue Details | |||||
0012953 | ParaView | (No Category) | public | 2012-02-21 09:10 | 2016-08-12 09:59 |
Reporter | RyanD | ||||
Priority | high | Severity | minor | Reproducibility | have not tried |
Product Version | 3.12 | ||||
Project | TBD | ||||
Topic Name | |||||
Type | crash | ||||
Summary | 0012953: Applying a texture through Python crashes Paraview | ||||
Description | I am trying to add a texture to a TextureMaptoPlane object via a Python script. Based on the trace information my script uses code like the following: t1 = TextureMaptoPlane() rep = Show() DataRepresentation7.Representation = 'Surface' rep.Texture = [PNGobject] Where PNGObject is a standard PNGSeriesReader with the desired texture png read in. Once the script reaches the line where the texture is set ParaView fails and outputs the following error message. ERROR: In /home/kitware/Dashboards/MyTests/ParaView-master/ParaViewCore/ServerImplementation/vtkPVSessionCore.cxx, line 324 vtkPVSessionCore (0x232b260): Object type: vtkGlyph3DRepresentation, could not find requested method: "SetTexture" or the method was called with incorrect arguments. while processing Message 0 = Invoke Argument 0 = vtk_object_pointer {vtkGlyph3DRepresentation (0x8a80170)} Argument 1 = string_value {SetTexture} Argument 2 = vtk_object_pointer {vtkFileSeriesReader (0x90dafd0)} ERROR: In /home/kitware/Dashboards/MyTests/ParaView-master/ParaViewCore/ServerImplementation/vtkPVSessionCore.cxx, line 325 vtkPVSessionCore (0x232b260): Aborting execution for debugging purposes. I don't know why it's referencing vtkGlyph3DRepresentation when my representation is set to Surface. | ||||
Steps To Reproduce | |||||
Relationships | |||||
Attached Files | |||||
Issue History | |||||
2012-02-21 09:10 | RyanD | New Issue | |||
2016-08-12 09:59 | Kitware Robot | Note Added: 0038143 | |||
Notes | |||||
