MantisBT - ParaView | |||||
View Issue Details | |||||
0012977 | ParaView | (No Category) | public | 2012-03-03 15:57 | 2016-08-12 09:59 |
Reporter | He Yuqi | ||||
Product Version | 3.14 | ||||
Project | Release | ||||
Topic Name | |||||
Summary | 0012977: Add support multi-configurations to fix library links in plugin | ||||
Description | The current ParaView build only can fixup library links correctly with Release configuartion by MSVC compiler in Windows box. Because the plugin library has located in ${EXECUTABLE_OUTPUT_PATH}/${CMAKE_INSTALL_CONFIG_NAME} folder if use MSVC IDE to compile, and located in ${EXECUTABLE_OUTPUT_PATH} folder if use NMAKE. Attached please found my patch to support multi-configurations that compiling by MSVC IDE and all configurations that compiling by NMAKE tool. | ||||
Steps To Reproduce | |||||
Relationships | |||||
Attached Files | paraview-win32-fixup-bundle.patch (2,709) 2012-03-03 15:57 https://www.vtk.org/Bug/file/9125/paraview-win32-fixup-bundle.patch | ||||
Issue History | |||||
2012-03-03 15:57 | He Yuqi | New Issue | |||
2012-03-03 15:57 | He Yuqi | File Added: paraview-win32-fixup-bundle.patch | |||
2016-08-12 09:59 | Kitware Robot | Note Added: 0038153 | |||
Notes | |||||
