MantisBT - ParaView | |||||
View Issue Details | |||||
0013137 | ParaView | (No Category) | public | 2012-04-26 19:59 | 2016-08-12 09:59 |
Reporter | Danielle Pace | ||||
Product Version | 3.14 | ||||
Project | TBD | ||||
Topic Name | |||||
Summary | 0013137: Cannot save images created using python calculator | ||||
Description | Cannot save image data that was created using the python calculator. Often I use paraview to do simple arithmetic on image data, which I then would like to save for further processing. Not being able to do so with the python calculator is quite limiting. Minimal example, with Paraview 3.14.0 on Ubuntu. - Load image - Python calculator: Expression: inputs[0].PointData['MetaImage'] // i.e. just copy data over Array Association: point data Copy arrays: off - Resulting image looks good - Select python calculator result, File->Save Data, save as .mhd - Reload image - data extents are correct, but all values are 0 Somewhat similarly - If you use the Calculator instead of the Python Calculator, there is no way to turn off "copy arrays", so the output image typically has two data arrays - the original input array, and the result of the calculation. If you save this as .mhd, the result has only one data array - the result of the calculation. I would expect a .mhd with two channels. | ||||
Steps To Reproduce | |||||
Relationships | |||||
Attached Files | |||||
Issue History | |||||
2012-04-26 19:59 | Danielle Pace | New Issue | |||
2016-08-12 09:59 | Kitware Robot | Note Added: 0038205 | |||
Notes | |||||
