MantisBT - ParaView | |||||
View Issue Details | |||||
0013203 | ParaView | (No Category) | public | 2012-05-24 16:58 | 2016-08-12 09:59 |
Reporter | Burlen | ||||
Product Version | 3.14 | ||||
Project | TBD | ||||
Topic Name | |||||
Summary | 0013203: slice rep ignores dataset origin in 3.14.x in client-server mode | ||||
Description | in past version of pv slice representation image data has been rendered with dataset positioned in the scene at it's origin. this changed in 3.14 where in the dataset origin is ignored and the dataset is rendered at 0,0,0. The following datasets illustrate. d1 has an origin of 0,0 spacing of 1,1 and extent is 20 30 20 30, while d2 has an origin of 20 30 spacing of 1,1 and an extent of 0 10 0 10. These should be rendered in the same location, however they are not. Changing from slice to another representation fixes the issue. this only happens in client server mode. | ||||
Steps To Reproduce | |||||
Relationships | |||||
Attached Files | d1.vti (2,381) 2012-05-24 16:58 https://www.vtk.org/Bug/file/9199/d1.vti d2.vti (2,379) 2012-05-24 16:58 https://www.vtk.org/Bug/file/9200/d2.vti | ||||
Issue History | |||||
2012-05-24 16:58 | Burlen | New Issue | |||
2012-05-24 16:58 | Burlen | File Added: d1.vti | |||
2012-05-24 16:58 | Burlen | File Added: d2.vti | |||
2016-08-12 09:59 | Kitware Robot | Note Added: 0038216 | |||
Notes | |||||
