MantisBT - ParaView
View Issue Details
0013210ParaView(No Category)public2012-05-29 16:042016-08-12 09:59
Sven Buijssen
Chris Harris
highminorhave not tried
closedmoved
3.14.1
TBD
0013210_parallel_exodus_fix
crash
0013210: vtkExodusIIWriter segfaults while attempting to save wavelet source
Refactoring of Exodus writer in mid May 2012 has introduced a regression into git/master:
Sources - Wavelet - Apply
File - Save Data - File name: foo.ex2 - Files of type: Exodus II file - Ok
Ok
=> segfault in vtkExodusIIWriter.cxx:1645-1646 due to attempted array out of bounds access as 'numElts' is 0:
    if (numNodes == 0)
      numPoints = blockIter->second.EntityNodeOffsets[numElts - 1]
                + blockIter->second.EntityCounts[numElts - 1];
No tags attached.
Issue History
2012-05-29 16:04Sven BuijssenNew Issue
2012-05-30 09:35Chris HarrisAssigned To => Chris Harris
2012-05-30 09:51Chris HarrisNote Added: 0028658
2012-05-31 08:35Chris HarrisTopic Name => 0013210_parallel_exodus_fix
2012-05-31 08:35Chris HarrisStatusbacklog => gatekeeper review
2012-06-01 14:40Utkarsh AyachitFixed in Version => git-master
2012-06-01 14:41Utkarsh AyachitStatusgatekeeper review => customer review
2012-06-01 14:41Utkarsh AyachitNote Added: 0028661
2012-07-19 16:41Alan ScottNote Added: 0028875
2012-07-19 16:41Alan ScottStatuscustomer review => todo
2012-07-19 16:42Alan ScottNote Added: 0028876
2012-07-19 16:42Alan ScottPrioritynormal => high
2012-07-24 16:19Chris HarrisNote Added: 0028910
2012-07-24 17:29Sven BuijssenNote Added: 0028916
2012-07-25 10:32Chris HarrisNote Added: 0028921
2012-07-25 11:56Chris HarrisNote Added: 0028923
2012-07-25 13:37Chris HarrisNote Added: 0028925
2012-10-29 17:04Utkarsh AyachitFixed in Versiongit-master => 3.98.0
2016-08-12 09:59Kitware RobotNote Added: 0038220
2016-08-12 09:59Kitware RobotStatustodo => closed
2016-08-12 09:59Kitware RobotFixed in Version3.98.0 =>
2016-08-12 09:59Kitware RobotResolutionopen => moved
Notes
(0028658)
Chris Harris
2012-05-30 09:51
A fix for this has been pushed to VTK:
http://review.source.kitware.com/#/t/747/ [^]
(0028661)
Utkarsh Ayachit
2012-06-01 14:41
Merged in master, if applicable.
(0028875)
Alan Scott
2012-07-19 16:41
Chris,
It dies remote server.
Linux, remote server, Master. I just followed your excellent directions below.
(0028876)
Alan Scott
2012-07-19 16:42
Making it high priority, since if it doesn't work remote server, it doesn't work. Further, this is the main way we write out datasets.
(0028910)
Chris Harris
2012-07-24 16:19
I am unable to recreate this problem. I can connect to a remote server and write out a file without a crash. Is the remote server running master?
(0028916)
Sven Buijssen
2012-07-24 17:29
Using a debug build of the git master branch on Linux x86_64, the segfault is gone when having connected to a single, separately started pvserver (both 'mpirun -np 1 /path/to/pvserver' and 'pvserver' work).
But having connected to a dual server, pvserver crashes while trying to save with:
% mpirun -np 2 /scratch/pv-git-build/bin/pvserver
Waiting for client...
Connection URL: cs://host:11111
Accepting connection(s): host:11111
Client connected.
Warning: In /scratch/pv.git/VTK/IO/Exodus/vtkExodusIIWriter.cxx, line 780
vtkPExodusIIWriter (0x1c9ed90): Attempting to proceed without metadata
vtkPExodusIIWriter (0x18990d0): Attempting to proceed without metadata
[host:13327] *** Process received signal ***
[host:13327] Signal: Segmentation fault (11)
[host:13327] Signal code: Address not mapped (1)
[host:13327] Failing at address: 0xfffffffffffffffc
[host:13326] *** Process received signal ***
[host:13326] Signal: Segmentation fault (11)
[host:13326] Signal code: Address not mapped (1)
[host:13326] Failing at address: 0xfffffffffffffffc
[host:13327] [ 0] /lib/libpthread.so.0(+0xf8f0) [0x7f086c6338f0]
[host:13327] [ 1] /scratch/pv-git-build/lib/libvtkIOExodus-6.0.so.1(_ZN17vtkExodusIIWriter21WriteBlockInformationEv+0x19e) [0x7f087fed75ba]
[host:13327] [ 2] /scratch/pv-git-build/lib/libvtkIOExodus-6.0.so.1(_ZN17vtkExodusIIWriter9WriteDataEv+0xdce) [0x7f087fed0ce0]
[host:13327] [ 3] /scratch/pv-git-build/lib/libvtkIOExodus-6.0.so.1(_ZN17vtkExodusIIWriter11RequestDataEP14vtkInformationPP20vtkInformationVectorS3_+0xc5) [0x7f087fecfe7d]
[host:13327] [ 4] /scratch/pv-git-build/lib/libvtkIOExodus-6.0.so.1(_ZN17vtkExodusIIWriter14ProcessRequestEP14vtkInformationPP20vtkInformationVectorS3_+0x225) [0x7f087fecfc9d]
[host:13327] [ 5] /scratch/pv-git-build/lib/libvtkCommonExecutionModel-6.0.so.1(_ZN12vtkExecutive13CallAlgorithmEP14vtkInformationiPP20vtkInformationVectorS3_+0x8d) [0x7f086860b30b]
When using Multi-Core via AutoMPI instead (Edit - Settings - General - Use Multi-Core), the server crashes while saving with a different error message:
% /scratch/pv-git-build/bin/paraview -dr
Process started
AutoMPI: SUCCESS: command is:
 "/scratch/openmpi/gcc4.4.3/1.4.3/bin/mpiexec" "-np" "2" "/scratch/pv-git-build/bin/pvserver" "--server-port=50577"
AutoMPI: starting process server
-------------- server output --------------
AutoMPI: server sucessfully started.
ERROR: In /scratch/pv.git/VTK/Parallel/Core/vtkSocketCommunicator.cxx, line 812
vtkSocketCommunicator (0x32db740): Could not receive tag. 188969
(0028921)
Chris Harris
2012-07-25 10:32
Ok, so this is a problem with the parallel implementation. I can recreate this using the instruction above.
(0028923)
Chris Harris
2012-07-25 11:56
This appear not to be a bug introduced by the refactoring for VTK modular. I ran the same test with 3.14 and see the same behavior.
(0028925)
Chris Harris
2012-07-25 13:37
Also fails with 3.12
(0038220)
Kitware Robot
2016-08-12 09:59
Resolving issue as `moved`.
