MantisBT - ParaView | |||||
View Issue Details | |||||
0013264 | ParaView | (No Category) | public | 2012-06-22 16:24 | 2016-08-12 09:59 |
Reporter | Alan Scott | ||||
Product Version | 3.14 | ||||
Project | Sandia | ||||
Topic Name | |||||
Summary | 0013264: pvbatch surface with edges, opacity draws funny in parallel | ||||
Description | A user found a bug with python. Basically, when you are showing surface with edges, with a non 1.0 opacity, the surface with edges draws with triangles rather than rectangles. This seems to only happen in parallel. In serial (pvpython), it works fine. 8 pvbatch's, a Linux cluster, 3.14.0. I am including a python file that shows this, along with two screenshots - good and bad. | ||||
Steps To Reproduce | |||||
Relationships | |||||
Attached Files | surface-with-edges-opacity.py (2,039) 2012-06-22 16:24 https://www.vtk.org/Bug/file/9217/surface-with-edges-opacity.py good.png (18,530) 2012-06-22 16:25 https://www.vtk.org/Bug/file/9218/good.png bad.png (50,622) 2012-06-22 16:25 https://www.vtk.org/Bug/file/9219/bad.png BUG.13264.patch (8,504) 2013-07-01 16:09 https://www.vtk.org/Bug/file/9474/BUG.13264.patch | ||||
Issue History | |||||
2012-06-22 16:24 | Alan Scott | New Issue | |||
2012-06-22 16:24 | Alan Scott | File Added: surface-with-edges-opacity.py | |||
2012-06-22 16:25 | Alan Scott | File Added: good.png | |||
2012-06-22 16:25 | Alan Scott | File Added: bad.png | |||
2013-01-24 23:24 | Utkarsh Ayachit | Note Added: 0030245 | |||
2013-07-01 14:15 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit | ||
2013-07-01 15:19 | Utkarsh Ayachit | Note Added: 0031111 | |||
2013-07-01 16:09 | Utkarsh Ayachit | Note Edited: 0031111 | bug_revision_view_page.php?bugnote_id=31111#r624 | ||
2013-07-01 16:09 | Utkarsh Ayachit | File Added: BUG.13264.patch | |||
2013-07-01 16:10 | Utkarsh Ayachit | Note Edited: 0031111 | bug_revision_view_page.php?bugnote_id=31111#r625 | ||
2016-08-12 09:59 | Kitware Robot | Note Added: 0038232 | |||
Notes | |||||
