MantisBT - ParaView | |||||
View Issue Details | |||||
0013352 | ParaView | (No Category) | public | 2012-08-11 10:22 | 2016-08-12 09:59 |
Reporter | Sebastien Jourdain | ||||
Assigned To | Sebastien Jourdain | ||||
Product Version | |||||
Project | TBD | ||||
Topic Name | |||||
Summary | 0013352: XML definition issue with comparative view | ||||
Description | I will have this kind of problem every time I do like this: 1). I open a series of mesh files as mesh* files. 2). Then I open a layout view by click the '+' sign. A new tab with 2x2 views are generated. 3). Then if I add a 3D glyph and choose in the property tab glyph type as 'line', a output message window pops out and it says: Generic Warning: In ..\..\..\..\src\ParaViewCore\ServerManager\vtkSMPropertyHelper.cxx, line 729 Call not supported for the current property type. If I choose tab glyph type as 'arrow', there is not this warning. another thing is that some times if I would like to change 'glyph type' from 'arrow' to 'line', only the glyph in the first view of the nxn views changes from the arrow to line, there others remain to be arrow. but then if I close the comparative tab, paraview will crash. | ||||
Steps To Reproduce | |||||
Relationships | |||||
Attached Files | |||||
Issue History | |||||
2012-08-11 10:22 | Sebastien Jourdain | New Issue | |||
2012-08-11 10:22 | Sebastien Jourdain | Assigned To | => Sebastien Jourdain | ||
2016-08-04 15:21 | Cory Quammen | Note Added: 0036684 | |||
2016-08-04 15:21 | Cory Quammen | Status | backlog => customer review | ||
2016-08-04 15:21 | Cory Quammen | Resolution | open => fixed | ||
2016-08-12 09:59 | Kitware Robot | Note Added: 0038247 | |||
2016-08-12 09:59 | Kitware Robot | Status | customer review => closed | ||
2016-08-12 09:59 | Kitware Robot | Resolution | fixed => moved |
Notes | |||||
