MantisBT - ParaView | |||||
View Issue Details | |||||
0013783 | ParaView | (No Category) | public | 2013-01-11 20:33 | 2016-08-12 09:59 |
Reporter | Alan Scott | ||||
Product Version | git-master | ||||
Project | Sandia | ||||
Topic Name | |||||
Summary | 0013783: 2d x axis numbers cut off | ||||
Description | The 2d text for the numbers down the X axis are one pixel too high, cutting them off. This is fairly hard to replicate. I suspect it happens with datasets that are very, very small. Here is how I replicated it. Linux, local server, master. Sources/ Wavelet. Apply. Calculator. Formula == RTData*0.0001 Plot over line filter. X Axis Data = Use Data Array = Result (from calculator above). We are trying to make the X axis have very small numbers such as 0.006. Line Series should be only RTData. Apply. The top pixel of some of the numbers down the X axis are cut off. They are one pixel higher than the ones that aren't cut off on top. | ||||
Steps To Reproduce | |||||
Relationships | |||||
Attached Files | |||||
Issue History | |||||
2013-01-11 20:33 | Alan Scott | New Issue | |||
2016-07-14 18:34 | Alan Scott | Note Added: 0036493 | |||
2016-08-12 09:59 | Kitware Robot | Note Added: 0038313 | |||
Notes | |||||
