MantisBT - ParaView |
View Issue Details |
0013797 | ParaView | (No Category) | public | 2013-01-17 11:28 | 2015-01-11 08:23 |
Reporter | Utkarsh Ayachit | |
Assigned To | Utkarsh Ayachit | |
Status | closed | Resolution | fixed | |
Product Version | 4.0 | |
Target Version | 4.1 | Fixed in Version | 4.1 | |
Project | LANL-InSitu |
Topic Name | 13797_fix_chart_sizes, 14280_fix_multiview_rendering_in_batch |
Type | incorrect functionality |
Summary | 0013797: Cannot change the sizes for plot views in Python |
Description | Cannot change the sizes for plot views in Python.
It seems to be a valid attribute (CreateXYPlotView.ViewSize), but it's not having any affect when the image is saved (they all come out in the default 300x300.
For a normal 3D view, this would be GetRenderView.ViewSize = [1200, 800], for example. That works, but not for plots. |
Steps To Reproduce | |
Additional Information | |
Tags | No tags attached. |
Attached Files | |
2013-01-17 11:28 | Utkarsh Ayachit | New Issue | |
2013-01-17 11:29 | Utkarsh Ayachit | Target Version | => 4.0 |
2013-08-15 10:11 | Utkarsh Ayachit | Product Version | => 4.0 |
2013-08-15 10:11 | Utkarsh Ayachit | Target Version | 4.0 => 4.1 |
2013-09-23 10:35 | Utkarsh Ayachit | Project | ParaViewPro => LANL-InSitu |
2013-09-23 10:35 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2013-09-23 10:35 | Utkarsh Ayachit | Status | backlog => active development |
2013-09-23 11:57 | Utkarsh Ayachit | Topic Name | => 13797_fix_chart_sizes, 14280_fix_multiview_rendering_in_batch |
2013-09-23 11:57 | Utkarsh Ayachit | Note Added: 0031613 | |
2013-09-23 11:57 | Utkarsh Ayachit | Status | active development => gatekeeper review |
2013-09-23 11:57 | Utkarsh Ayachit | Resolution | open => fixed |
2013-09-23 11:58 | Utkarsh Ayachit | Note Added: 0031614 | |
2013-09-23 11:58 | Utkarsh Ayachit | Status | gatekeeper review => active development |
2013-09-26 13:37 | Utkarsh Ayachit | Note Deleted: 0031613 | |
2013-09-26 13:37 | Utkarsh Ayachit | Note Deleted: 0031614 | |
2013-09-26 13:37 | Utkarsh Ayachit | Note Added: 0031636 | |
2013-09-26 13:37 | Utkarsh Ayachit | Status | active development => gatekeeper review |
2013-09-26 13:37 | Utkarsh Ayachit | Fixed in Version | => git-next |
2013-09-26 13:38 | Utkarsh Ayachit | Note Added: 0031637 | |
2013-09-30 09:21 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2013-09-30 09:21 | Utkarsh Ayachit | Note Added: 0031662 | |
2013-10-21 08:16 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
2013-11-01 13:17 | Utkarsh Ayachit | Fixed in Version | git-master => 4.1 |
2014-04-08 21:37 | Alan Scott | Note Added: 0032572 | |
2014-04-08 21:37 | Alan Scott | Status | customer review => closed |
2015-01-11 08:23 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master d17968f7 |
2015-01-11 08:23 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 1b402c18 |
(0031636)
Utkarsh Ayachit
2013-09-26 13:37
commit 1b402c182de4b8f9b8395d034c36353073dc4db2
Date: Mon Sep 23 11:51:53 2013 -0400
BUG 0013797. Fixed chart view size issues with pvbatch.
Chart view sizes weren't having any effect in pvbatch. The problem was that the
logic to resize the windows which was in vtkPVSynchronizedRenderWindows was
never called since the vtkPVSynchronizedRenderWindows instance is not enabled
for chart views (since they don't do parallel rendering). It worked for 3D views
since vtkPVRenderView always enabled the vtkPVSynchronizedRenderWindows in batch
mode.
Fixed the logic by making sure that vtkPVSynchronizedRenderWindows lays out the
views/renders in batch mode even for chart views. This also address the bug fix
for BUG 0014280.
Change-Id: I3c99a7a267bbe8ad45b7fbc428b3e13ed3433e43 |
(0031637)
Utkarsh Ayachit
2013-09-26 13:38
Piggybacking another fix:
commit 3033c8ca8eb3b1afaee75d8ec5990247ece1d674
Date: Tue Sep 24 13:36:23 2013 -0400
Fix logic to compute the magnitude range.
The logic was incorrectly computing the range for vector magnitude. Fixed it to
use the proper API on vtkPVArrayInformation.
Change-Id: Iebf04d8dc3a339d6cbe8267711f90726e711e854 |
(0031662)
Utkarsh Ayachit
2013-09-30 09:21
SUMMARY
Topics merged into master:
0014284_fix_color_map
14287_fix_proxy_delete
14289_fix_extent_issues
14299_fix_contour_panel
14309-chart-selection-buggy
fix_python_windows_coprocessing
(VTK) forward-to-vtk-master
(VTK) parallel-surface-lic-pv
sqtk-fix-some-issues
(0032572)
Alan Scott
2014-04-08 21:37
