MantisBT - ParaView |
View Issue Details |
0013807 | ParaView | (No Category) | public | 2013-01-21 11:04 | 2013-12-24 19:55 |
Reporter | Alejandro Ribes | |
Assigned To | | |
Status | closed | Resolution | fixed | |
Product Version | 3.98.1 | |
Target Version | | Fixed in Version | 4.0 | |
Project | ParaViS |
Topic Name | 13807-apply-current-panel-only-option |
Type | incorrect functionality |
Summary | 0013807: Bug when opening several files at the same time |
Description | Hello,
There is a bug when opening several files at the same time. As an example, I have two files (in this particular case a vtp and a vtu but works with any file), I "open" both of them but do not click on Apply. Once both of them appear in the pipeline browser I select one and click Apply THEN both of them are loaded. This looks like a bug.
Regards,
Alejandro.
Steps To Reproduce | |
Additional Information | |
Tags | No tags attached. |
Attached Files | |
2013-01-21 11:04 | Alejandro Ribes | New Issue | |
2013-03-12 09:13 | Utkarsh Ayachit | Status | backlog => todo |
2013-03-12 09:13 | Utkarsh Ayachit | Assigned To | => Kyle Lutz |
2013-03-12 13:51 | Kyle Lutz | Note Added: 0030425 | |
2013-03-12 13:51 | Kyle Lutz | Status | todo => gatekeeper review |
2013-03-12 13:51 | Kyle Lutz | Resolution | open => fixed |
2013-03-14 10:38 | Utkarsh Ayachit | Fixed in Version | => git-master |
2013-03-14 10:39 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2013-03-14 10:39 | Utkarsh Ayachit | Note Added: 0030428 | |
2013-03-14 13:01 | Alejandro Ribes | Note Added: 0030439 | |
2013-03-18 13:45 | Utkarsh Ayachit | Note Added: 0030446 | |
2013-03-19 10:43 | Alejandro Ribes | Note Added: 0030451 | |
2013-03-19 10:50 | Utkarsh Ayachit | Note Added: 0030452 | |
2013-03-19 10:50 | Utkarsh Ayachit | Status | customer review => todo |
2013-04-03 11:51 | Kyle Lutz | Status | todo => active development |
2013-04-03 12:52 | Kyle Lutz | Topic Name | => 13807-apply-current-panel-only-option |
2013-04-03 12:52 | Kyle Lutz | Note Added: 0030509 | |
2013-04-03 12:52 | Kyle Lutz | Status | active development => gatekeeper review |
2013-04-03 12:54 | Kyle Lutz | Note Added: 0030510 | |
2013-04-05 09:03 | Sebastien Jourdain | Status | gatekeeper review => customer review |
2013-04-05 09:03 | Sebastien Jourdain | Note Added: 0030526 | |
2013-05-18 20:00 | Utkarsh Ayachit | Fixed in Version | git-master => 4.0 |
2013-12-24 19:55 | Alan Scott | Note Added: 0032069 | |
2013-12-24 19:55 | Alan Scott | Status | customer review => closed |
2013-12-24 19:55 | Alan Scott | Assigned To | Kyle Lutz => |
(0030425)
Kyle Lutz
2013-03-12 13:51
This is the expected behaviour. This was the case with 3.14 and earlier. The rationale is that users can change multiple properties on several filters/source (or open multiple files) and then apply them all at once.
Has your use-case changed recently? If so, we can maybe provide a settings option or a special right-click context menu on Apply to "Apply Currrent Only" or something to that effect. |
(0030428)
Utkarsh Ayachit
2013-03-14 10:39
SUMMARY
Topics merged into master:
0013926-webgl-support
0013940-enable-paraview-web-build
13927_fix_text_bounding_boxes
13928-print-monitors
13930_XMLP_writers
13938_blot_color_table
13939-vr-cache-state
(VTK) composite-data-display-attributes
fix-ordered-composite-distributor-return
fix_unnecessary_rebuilds
(VTK) update_vtk_master
(0030439)
Alejandro Ribes
2013-03-14 13:01
Hi Kyle,
This bug entry is coming from one of my user-department's requirements. I already contacted them by email and try to know what they prefer. In any case, what do you think is better? An option is maybe good but people will forget it, is a contextual right-click compatible with the philosophy of ParaView?
Cheers,
Alejandro. |
(0030446)
Utkarsh Ayachit
2013-03-18 13:45
Alejandro,
You're are right, it's not common for ParaView user's to expect the Apply button to have a context menu. Let's see what your users prefer and then decide. |
(0030451)
Alejandro Ribes
2013-03-19 10:43
Hello,
I spoke with my users and they prefer a settings option. This is good because, as Utkarsh says, nobody expects a context menu in the apply button :) Of course the default behaviour will be the current behaviour.
Cheers,
Alejandro. |
(0030452)
Utkarsh Ayachit
2013-03-19 10:50
Let's add a settings option to control if we apply "All" changes or only the "current" panel's changes. |
(0030509)
Kyle Lutz
2013-04-03 12:52
Merge topic '13807-apply-current-panel-only-option' into next
e5b080b Add 'Only Apply Current Panel' option |
(0030510)
Kyle Lutz
2013-04-03 12:54
I've added a new option in the Edit->Settings menu named 'Only Apply Current Panel` which will cause the Apply button to only apply settings for the currently active panel/proxy. By default it is disabled to stay with the previous behavior. |
(0030526)
Sebastien Jourdain
2013-04-05 09:03
(0032069)
Alan Scott
2013-12-24 19:55
Old customer review bug. Closing untested. |
