MantisBT - ParaView |
View Issue Details |
0013810 | ParaView | (No Category) | public | 2013-01-22 06:30 | 2015-01-11 08:26 |
Reporter | Alejandro Ribes | |
Assigned To | Utkarsh Ayachit | |
Status | closed | Resolution | fixed | |
Product Version | 3.98.1 | |
Target Version | | Fixed in Version | 4.0 | |
Project | ParaViS |
Topic Name | refactor_panels |
Type | incorrect functionality |
Summary | 0013810: Bug in "Properties" tap when charging the Point Sprite Plugin |
Description | Hello,
I have a file containing point sprites. I open it when the "Point Sprite" plugin is not loaded and the Properties tap is normal. When I open it with the plugin loaded the Properties Tap is buggy, it presents all buttons deformed to the right, they are excessively long and this make them very difficult for interaction. I found that behavior in ParaView 3.98.
Regards,
Alejandro. |
Steps To Reproduce | |
Additional Information | |
Tags | No tags attached. |
Attached Files | |
2013-01-22 06:30 | Alejandro Ribes | New Issue | |
2013-03-12 09:13 | Utkarsh Ayachit | Status | backlog => todo |
2013-03-18 17:19 | Utkarsh Ayachit | Assigned To | => Kyle Lutz |
2013-04-03 11:03 | Kyle Lutz | Status | todo => active development |
2013-04-23 11:29 | Utkarsh Ayachit | Assigned To | Kyle Lutz => Utkarsh Ayachit |
2013-04-23 13:45 | Utkarsh Ayachit | Topic Name | => refactor_panels |
2013-04-23 13:45 | Utkarsh Ayachit | Note Added: 0030603 | |
2013-04-23 13:45 | Utkarsh Ayachit | Status | active development => gatekeeper review |
2013-04-23 13:45 | Utkarsh Ayachit | Fixed in Version | => git-next |
2013-04-23 13:45 | Utkarsh Ayachit | Resolution | open => fixed |
2013-04-25 09:22 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
2013-04-25 09:24 | Utkarsh Ayachit | Note Added: 0030617 | |
2013-04-25 09:24 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2013-05-18 20:00 | Utkarsh Ayachit | Fixed in Version | git-master => 4.0 |
2013-10-09 08:18 | Alejandro Ribes | Note Added: 0031685 | |
2013-10-21 07:39 | Utkarsh Ayachit | Note Added: 0031703 | |
2014-04-08 21:36 | Alan Scott | Note Added: 0032570 | |
2014-04-08 21:36 | Alan Scott | Status | customer review => closed |
2015-01-11 08:26 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master fded7f00 |
2015-01-11 08:26 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 7017d50a |
(0030603)
Utkarsh Ayachit
2013-04-23 13:45
commit 7017d50ab0c3d8481fbca73c7352057299c422cf
Date: Tue Apr 23 13:39:46 2013 -0400
BUG 0013810. Fixing PointSprites panel to work with new panels.
This is a quick hack, simply duplicating the existing code from
pqPointSpriteDisplayPanelDecorator in pqPointSpriteControls. There is
considerable cleanup that is needed to ensure this representation works in a
coherant manner with the rest of the application (currently this representation
uses several non-standard *tricks* that can easily break.
Change-Id: I3b6748b8f60d77890f1fa690a32150ca100b3eb7 |
(0030617)
Utkarsh Ayachit
2013-04-25 09:24
SUMMARY
Topics merged into master:
13450_update_tests_to_use_new_panels
(VTK) 14023-plot3d-function-support
14026_catalyst_python_warning
14032_fix_CoProcessingTestInput
fix_protobuf_try_compiles
pvw-python-refactoring
pvw-remove-example
refactor_panels
(VTK) update_vtk_master
zoom-to-data-icon
fix_cmake_2.8.10_plugins_issue
(0031685)
Alejandro Ribes
2013-10-09 08:18
Hi,
I would like to know if this bug is completely corrected now.
Cheers,
Alejandro. |
(0031703)
Utkarsh Ayachit
2013-10-21 07:39
Alejandro,
This is indeed fixed in git/master. Feel free to give it a go and let me know if you see any other issues. |
(0032570)
Alan Scott
2014-04-08 21:36
