MantisBT - ParaView | ||||||||||
View Issue Details | ||||||||||
ID | Project | Category | View Status | Date Submitted | Last Update | |||||
0013961 | ParaView | (No Category) | public | 2013-03-22 14:46 | 2013-03-22 18:56 | |||||
Reporter | Alan Scott | |||||||||
Assigned To | Alan Scott | |||||||||
Priority | high | Severity | minor | Reproducibility | have not tried | |||||
Status | closed | Resolution | fixed | |||||||
Platform | OS | OS Version | ||||||||
Product Version | git-master | |||||||||
Target Version | Fixed in Version | |||||||||
Project | Sandia | |||||||||
Topic Name | ||||||||||
Type | incorrect functionality | |||||||||
Summary | 0013961: TableToPoints filter and TableToStructuredGrid scalars broken | |||||||||
Description | Table to Points, and Table to Structured Grid are not converting any scalars correctly. I believe this makes the CSV reader pretty useless... Master, Linux or Windows, local server. Put the following into a file named scalarBug.txt: x coord, y coord, z coord, scalar 0, 0, 0, 0 1, 0, 0, 1 0, 1, 0, 2 1, 1, 0, 3 -0.5, -0.5, 1, 4 0.5, -0.5, 1, 5 -0.5, 0.5, 1, 6 0.5, 0.5, 1, 7 * Now, read this file into ParaView using the Delimited Text reader (default). Take default settings. Apply. * Filters/ Alphabetical/ Table to Point filter. X Column == x coord, Y Column == y coord, Z Column == z coord. Apply. * Now, split screen horizontally, and make the new window a 3d window. Turn on visibility of the Table to Point filter. * Change color to "scalar" (which was in the table above). Add a color legend. <<Bug>> The points are not colored properly, and the color legend range will go from -inf to inf (actually, -1e299 to 1e299). The same issue occurs with the Table To Structured Grid filter. Marking high, since I believe this makes the delimited text reader useless. | |||||||||
Steps To Reproduce | ||||||||||
Additional Information | ||||||||||
Tags | No tags attached. | |||||||||
Attached Files | ||||||||||
Issue History | ||||||||||
Date Modified | Username | Field | Change | |||||||
2013-03-22 14:46 | Alan Scott | New Issue | ||||||||
2013-03-22 14:47 | Alan Scott | Description Updated | bug_revision_view_page.php?rev_id=571#r571 | |||||||
2013-03-22 14:48 | Alan Scott | Status | backlog => todo | |||||||
2013-03-22 16:35 | Ken Moreland | Note Added: 0030460 | ||||||||
2013-03-22 18:54 | Alan Scott | Relationship added | related to 0013962 | |||||||
2013-03-22 18:56 | Alan Scott | Note Added: 0030461 | ||||||||
2013-03-22 18:56 | Alan Scott | Status | todo => closed | |||||||
2013-03-22 18:56 | Alan Scott | Assigned To | => Alan Scott | |||||||
2013-03-22 18:56 | Alan Scott | Resolution | open => fixed |
Notes | |||||
