MantisBT - ParaView | |||||
View Issue Details | |||||
0013985 | ParaView | (No Category) | public | 2013-04-02 12:49 | 2015-01-02 10:45 |
Reporter | Joni-Pekka Kurronen | ||||
Assigned To | Cory Quammen | ||||
Status | closed | Resolution | no change required | ||
Product Version | |||||
Target Version | Fixed in Version | 4.3 | |||
Project | ParaViewVR | ||||
Topic Name | |||||
Summary | 0013985: Latest API changes has caused that 3dconnexion SpaceNavigator dose not wotk whit Praview | ||||
Description | After update while compile: vtktiff -- Found Qt4: /usr/bin/qmake (found suitable version "4.8.1", minimum required is "4.7.0") CMake Error at CMake/vtkClientServerWrapping.cmake:52 (vtk_module_classes_load): Unknown CMake command "vtk_module_classes_load". Call Stack (most recent call first): CMake/vtkClientServerWrapping.cmake:18 (pv_pre_wrap_vtk_mod_cs) Wrapping/ClientServer/CMakeLists.txt:9 (vtk_add_cs_wrapping) -- Configuring incomplete, errors occurred! make: *** [cmake_check_build_system] Virhe 1 joni@mpi1:/mpi3/S2/ParaView5-BUILD$ === build code: # http://www.paraview.org/Wiki/ParaView_VR_in_4.0cd [^] mkdir /mpi3/S2/ParaView5 cd /mpi3/S2/ParaView5 git clone git://paraview.org/ParaView.git [^] /mpi3/S2/ParaView5 git checkout master git pull origin master git submodule update --init # http://review.source.kitware.com/#/c/8375/2 [^] # git fetch http://review.source.kitware.com/p/ParaView [^] refs/changes/74/8374/2 && git checkout FETCH_HEAD -b add_space_navigator_support # Fixed linking error in VR plugin git fetch http://review.source.kitware.com/p/ParaView [^] refs/changes/75/8375/2 && git checkout FETCH_HEAD -b add_space_navigator_support cd /mpi3/S2 mkdir ParaView5-BUILD cd ParaView5-BUILD cmake -i ../ParaView5 | ||||
Steps To Reproduce | |||||
Relationships | |||||
Attached Files | |||||
Issue History | |||||
2013-04-02 12:49 | Joni-Pekka Kurronen | New Issue | |||
2014-10-10 09:04 | Cory Quammen | Assigned To | => Cory Quammen | ||
2014-10-10 09:04 | Cory Quammen | Status | backlog => active development | ||
2014-10-10 09:04 | Cory Quammen | Note Added: 0033621 | |||
2014-10-10 09:04 | Cory Quammen | Status | active development => gatekeeper review | ||
2014-10-10 09:04 | Cory Quammen | Fixed in Version | => 4.2 | ||
2014-10-10 09:04 | Cory Quammen | Resolution | open => no change required | ||
2014-10-15 10:08 | Utkarsh Ayachit | Fixed in Version | 4.2 => git-master | ||
2014-10-15 10:08 | Utkarsh Ayachit | Status | gatekeeper review => customer review | ||
2014-10-15 10:08 | Utkarsh Ayachit | Note Added: 0033642 | |||
2014-11-06 20:20 | Alan Scott | Note Added: 0033775 | |||
2014-11-06 20:20 | Alan Scott | Status | customer review => closed | ||
2015-01-02 10:45 | Utkarsh Ayachit | Fixed in Version | git-master => 4.3 |
Notes | |||||
