MantisBT - ParaView | |||||
View Issue Details | |||||
0013996 | ParaView | (No Category) | public | 2013-04-04 04:52 | 2016-08-12 09:59 |
Reporter | Joachim Pouderoux | ||||
Priority | low | Severity | minor | Reproducibility | have not tried |
Product Version | 3.98.1 | ||||
Project | TBD | ||||
Topic Name | |||||
Summary | 0013996: Cell selection color | ||||
Description | It appears that cell selection (contrary to point selection) is affected by the lighting parameters. Thus, when you choose the selection color you will notice that (depending on the light used - headlight vs lightkit) the cells wireframe is not rendered with the exact choosen color. For instance if you choose a green color for the selection (with 1.0 opacity),the lines are rendered in white with the default Headlight. With the lightkit, the correct color is used. I guess it may be very difficult to understand for the end user... | ||||
Steps To Reproduce | |||||
Relationships | |||||
Attached Files | |||||
Issue History | |||||
2013-04-04 04:52 | Joachim Pouderoux | New Issue | |||
2016-08-12 09:59 | Kitware Robot | Note Added: 0038376 | |||
Notes | |||||
