MantisBT - ParaView |
View Issue Details |
0014054 | ParaView | (No Category) | public | 2013-05-07 16:03 | 2013-05-21 16:26 |
Reporter | Alan Scott | |
Assigned To | Yumin Yuan | |
Status | closed | Resolution | fixed | |
Product Version | git-master | |
Target Version | | Fixed in Version | 4.0 | |
Project | Sandia |
Topic Name | 14054_slice_crinkle_bug |
Type | incorrect functionality |
Summary | 0014054: crinkle slice the glyph is wrong |
Description | If you slice with a crinkle slice, then glyph, the whole dataset will be glyphed.
Master, Linux, local server.
Open can.exo. Apply.
Slice filter. Crinkle slice on, Show plane off. Apply.
<Important> - go forward one time step. (otherwise, scales are bad and paraview may hang).
Glyph filter. Apply.
Notice that the whole can is glyph-ed - not just the slice. This is a bug.
Steps To Reproduce | |
Additional Information | |
Tags | No tags attached. |
Attached Files | |
2013-05-07 16:03 | Alan Scott | New Issue | |
2013-05-13 10:51 | Utkarsh Ayachit | Assigned To | => Yumin Yuan |
2013-05-13 15:23 | Yumin Yuan | Status | backlog => todo |
2013-05-13 15:23 | Yumin Yuan | Status | todo => active development |
2013-05-15 15:36 | Yumin Yuan | Note Added: 0030776 | |
2013-05-20 14:00 | Yumin Yuan | Topic Name | => 14054_slice_crinkle_bug |
2013-05-20 14:00 | Yumin Yuan | Note Added: 0030802 | |
2013-05-20 14:00 | Yumin Yuan | Status | active development => gatekeeper review |
2013-05-20 14:00 | Yumin Yuan | Fixed in Version | => git-next |
2013-05-20 14:00 | Yumin Yuan | Resolution | open => fixed |
2013-05-21 11:03 | Utkarsh Ayachit | Fixed in Version | git-next => 4.0 |
2013-05-21 11:06 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2013-05-21 11:06 | Utkarsh Ayachit | Note Added: 0030806 | |
2013-05-21 16:26 | Alan Scott | Note Added: 0030809 | |
2013-05-21 16:26 | Alan Scott | Status | customer review => closed |
(0030776)
Yumin Yuan
2013-05-15 15:36
(0030802)
Yumin Yuan
2013-05-20 14:00
Fixed wrongful logic for ExtractOnlyBoundaryCells in vtkExtractGeometry.
The ExtractOnlyBoundaryCells is not working properly due to some logic
errors in deciding when to extract cells if both ExtractBoundaryCells
and ExtractOnlyBoundaryCells are on. Fixed it.
Change-Id: I0574c672507ca610b1e77272d12f4e8acc3efa0c |
(0030806)
Utkarsh Ayachit
2013-05-21 11:06
SUMMARY
Topics merged into master:
14072_splash_default_off
14075_coprocessing_script_generator
fix-install-www-rules
fix_multiblock_inspector_issues
fix_python_paths
update_vtk |
(0030809)
Alan Scott
2013-05-21 16:26
Excellent.
Tested master, remote server, Linux. |
