MantisBT - ParaView | |||||
View Issue Details | |||||
0014145 | ParaView | (No Category) | public | 2013-06-24 16:46 | 2016-08-12 09:59 |
Reporter | William Oquendo | ||||
Product Version | 4.0 | ||||
Project | TBD | ||||
Topic Name | |||||
Summary | 0014145: When oppened from the command line, Paraview does not have a default reader for .pvd files but still works | ||||
Description | I am starting using Paraview 4.0.1 . If I open a pvd from the command line as open -a paraview filename.pvd I get a window, title Open data with ... asking me for a reader! (see screenshot at the end). The list of readers is empty. If I select ok or cancel the data is read. If open directly from paraview, no message like that appears. The expected behaviour is to open the pvd file directly without any reader question, or at least to show the pvd reader in the reader list. I am working in Mac OS X 10.8.4, with the latest stable paraview release, paraview-4.0.1-darwin-64bit.dmg. This also happens for the Lion version. AND ALSO HAPPENS FOR .vtp files. Version 3.98 works without a problem (i.e when oppening from the command line it just opens the datafile without asking for a reader for pvd files.) The pvd data file is very simple: <?xml version="1.0"?> <VTKFile type="Collection" version="0.1" byte_order="LittleEndian"> <Collection> <DataSet timestep="0.2217153600089431" file="data-0000000000000000.vtp" /> </Collection> </VTKFile> | ||||
Steps To Reproduce | |||||
Relationships | |||||
Attached Files | Screen Shot 2013-06-20 at 6.37.38 AM.png (68,857) 2013-06-24 16:46 https://www.vtk.org/Bug/file/9468/Screen%20Shot%202013-06-20%20at%206.37.38%20AM.png | ||||
Issue History | |||||
2013-06-24 16:46 | William Oquendo | New Issue | |||
2013-06-24 16:46 | William Oquendo | File Added: Screen Shot 2013-06-20 at 6.37.38 AM.png | |||
2016-08-12 09:59 | Kitware Robot | Note Added: 0038412 | |||
Notes | |||||
