(0031364)
Orion Poplawski
2013-07-29 23:22
I'm running into the same issue trying to update the Fedora paraview package. VTK_PYTHON_SETUP_ARGS doesn't seem to be available. And -DVTK_INSTALL_PYTHON_USING_CMAKE:BOOL=OFF doesn't appear to help. |
(0031431)
Atri
2013-08-11 17:28
I finally patched the CMakeLists file as follows. This gets paraview building again, although I do not know if this is the right thing to do or not...
Index: ParaView-v4.0.1-source/CMakeLists.txt
--- ParaView-v4.0.1-source.orig/CMakeLists.txt
+++ ParaView-v4.0.1-source/CMakeLists.txt
@@ -176,7 +176,7 @@ set (VTK_INSTALL_NO_QT_PLUGIN TRUE)
# ParaView install the vtk python modules specifically to appropriate locations.
set (VTK_INSTALL_NO_PYTHON TRUE)
-set (VTK_INSTALL_PYTHON_USING_CMAKE TRUE)
+set (VTK_INSTALL_PYTHON_USING_CMAKE FALSE)
# for temporary backwards compatibility.
set (PV_INSTALL_BIN_DIR ${VTK_INSTALL_RUNTIME_DIR}) |
(0031439)
Orion Poplawski
2013-08-12 16:43
So that's why setting on the command line had no effect! Works for me too. |
(0032392)
Utkarsh Ayachit
2014-02-24 10:57
Guys, has anyone tried this withg 4.1? The Python installation rules were updated for 4.1. Please let me know if the problem persists with 4.1 and we can track it down.
Thanks for all your help. |
(0032395)
Orion Poplawski
2014-02-24 11:07
4.1 appears to honor VTK_INSTALL_PYTHON_MODULE_DIR just fine and works for me. Thanks. |
(0032396)
Utkarsh Ayachit
2014-02-24 12:08
Great! I'll close this one then. Atri, please feel free to reopen if you run into problems. Thanks. |
(0032411)
Atri
2014-02-26 00:08
Thank you very much. VTK_INSTALL_PYTHON_MODULE_DIR works just fine for me too with version 4.1. |
