MantisBT - ParaView | |||||
View Issue Details | |||||
0014189 | ParaView | (No Category) | public | 2013-07-25 15:43 | 2016-08-12 09:59 |
Reporter | Utkarsh Ayachit | ||||
Assigned To | David Thompson | ||||
Product Version | |||||
Project | TBD | ||||
Topic Name | |||||
Summary | 0014189: vtkScalarsToColors::SetAnnotations(...) does not update correctly. | ||||
Description | If vtkScalarsToColors::SetAnnotations(..,...) is called with certain arrays, and those array are later changed from code outside vtkScalarsToColors, vtkScalarsToColors never realizes the change. Calling SetAnnotations(..) again has no effect. e.g. vtkVariantArray* foo=... vtkStringArray* bar=... /// fill values stc->SetAnnotations(foo, bar); /// Render/Update the LUT. Annotations shown/used as expected /// change values in foo and bar stc->SetAnnnotations(foo, bar); /// Render/Update the LUT. Annotations won't be changed, it will still /// use the old values. DOing the following overcomes the issue: stc->SetAnnnotations(NULL, NULL); stc->SetAnnnotations(foo, bar); | ||||
Steps To Reproduce | |||||
Relationships | |||||
Attached Files | |||||
Issue History | |||||
2013-07-25 15:43 | Utkarsh Ayachit | New Issue | |||
2013-07-25 15:43 | Utkarsh Ayachit | Assigned To | => David Thompson | ||
2016-08-12 09:59 | Kitware Robot | Note Added: 0038426 | |||
Notes | |||||
