MantisBT - ParaView | |||||
View Issue Details | |||||
0014236 | ParaView | (No Category) | public | 2013-08-16 13:18 | 2016-08-12 09:59 |
Reporter | Utkarsh Ayachit | ||||
Product Version | 4.0 | ||||
Project | Kitware | ||||
Topic Name | |||||
Summary | 0014236: vtkImplicitFunctionToImageStencil doesn't work in ParaView | ||||
Description | + Rebuild ParaView with Module_vtkImagingStencil Cmake variable ON + Load attached XML as a plugin. + Try creating the "Implicit-Function To Image-Stencil" source. + You'll get errors: Generic Warning: In /home/utkarsh/Kitware/ParaView3/ParaView/VTK/Common/DataModel/vtkDataObjectTypes.cxx, line 303 NewDataObject(): You are trying to instantiate DataObjectType "vtkImageStencilData" which does not exist. ERROR: In /home/utkarsh/Kitware/ParaView3/ParaView/VTK/Common/ExecutionModel/vtkDemandDrivenPipeline.cxx, line 658 vtkPVCompositeDataPipeline (0x20b9d80): Algorithm vtkImplicitFunctionToImageStencil(0x26c9770) did not create output for port 0 when asked by REQUEST_DATA_OBJECT and does not specify a concrete DATA_TYPE_NAME. Generic Warning: In /home/utkarsh/Kitware/ParaView3/ParaView/VTK/Common/DataModel/vtkDataObjectTypes.cxx, line 303 NewDataObject(): You are trying to instantiate DataObjectType "vtkImageStencilData" which does not exist. | ||||
Steps To Reproduce | |||||
Relationships | |||||
Attached Files | ImageFilters.xml (5,198) 2013-08-16 13:18 https://www.vtk.org/Bug/file/9503/ImageFilters.xml | ||||
Issue History | |||||
2013-08-16 13:18 | Utkarsh Ayachit | New Issue | |||
2013-08-16 13:18 | Utkarsh Ayachit | File Added: ImageFilters.xml | |||
2016-08-12 09:59 | Kitware Robot | Note Added: 0038437 | |||
Notes | |||||
