MantisBT - ParaView |
View Issue Details |
0014299 | ParaView | (No Category) | public | 2013-09-25 11:58 | 2015-01-11 08:23 |
Reporter | Utkarsh Ayachit | |
Assigned To | Utkarsh Ayachit | |
Status | closed | Resolution | fixed | |
Product Version | | |
Target Version | 4.1 | Fixed in Version | 4.1 | |
Project | Sandia |
Topic Name | 14299_fix_contour_panel |
Type | incorrect functionality |
Summary | 0014299: Contour panel not updating correctly |
Description | Steps to reproduce (make sure "Auto Apply" is not ON)
+ Wavelet, Apply
+ Contour, Apply -- all well so far
+ Click on the button below the "-" sign with the tooltip "add a range of values" to add a range of values to contour with. Accept the default values in the popup dialog.
BUG --> while the IsoSurfaces widget updates to show the new values, the Apply button doesn't go green!
Steps To Reproduce | |
Additional Information | |
Tags | No tags attached. |
Attached Files | |
2013-09-25 11:58 | Utkarsh Ayachit | New Issue | |
2013-09-25 11:59 | Utkarsh Ayachit | Target Version | => 4.1 |
2013-09-26 16:42 | Utkarsh Ayachit | Topic Name | => 14299_fix_contour_panel |
2013-09-26 16:42 | Utkarsh Ayachit | Note Added: 0031641 | |
2013-09-26 16:42 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
2013-09-26 16:42 | Utkarsh Ayachit | Fixed in Version | => git-next |
2013-09-26 16:42 | Utkarsh Ayachit | Resolution | open => fixed |
2013-09-26 16:42 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2013-09-30 09:21 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2013-09-30 09:21 | Utkarsh Ayachit | Note Added: 0031665 | |
2013-10-21 08:16 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
2013-10-30 22:27 | Alan Scott | Note Added: 0031790 | |
2013-10-30 22:27 | Alan Scott | Status | customer review => closed |
2013-11-01 13:17 | Utkarsh Ayachit | Fixed in Version | git-master => 4.1 |
2015-01-11 08:23 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master cce5465c |
2015-01-11 08:23 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master bffda434 |
(0031641)
Utkarsh Ayachit
2013-09-26 16:42
commit bffda434dfc82c531db50ef93602471660b7f7c4
Date: Thu Sep 26 16:41:38 2013 -0400
BUG 0014299: Fixed missing "modified" notification.
pqScalarValueListPropertyWidget wasn't firing appropriate signal when a range of
values were added to the widget. Fixed that.
Change-Id: I70581a3aacaddcc760290bc5d5b519c20d57de43 |
(0031665)
Utkarsh Ayachit
2013-09-30 09:21
SUMMARY
Topics merged into master:
0014284_fix_color_map
13797_fix_chart_sizes
14287_fix_proxy_delete
14289_fix_extent_issues
14309-chart-selection-buggy
fix_python_windows_coprocessing
(VTK) forward-to-vtk-master
(VTK) parallel-surface-lic-pv
sqtk-fix-some-issues
(0031790)
Alan Scott
2013-10-30 22:27
Tested local server, master, Linux. |
