(0031888)
Paul Edwards
2013-11-30 04:18
(edited on: 2013-12-04 17:02) |
Looks like this commit was adding support for compression with PNG images but set the default value to be 0 (no compression).
http://vtk.org/gitweb?p=VTK.git;a=commit;h=5d97d7df5c754d8609a746fdcb8d65736ab61f8b [^]
The compression level in the dialog isn't used unless jpeg is selected - it could be added in: ./ParaViewCore/ServerManager/Rendering/vtkSMUtilities.cxx (but would need to translate to the 0-9 that png writer expects).
(0031921)
Utkarsh Ayachit
2013-12-11 11:43
Thanks for the solution, Paul. That makes it easier :)! |
(0031941)
Utkarsh Ayachit
2013-12-16 11:40
(0032024)
Dan Lipsa
2013-12-18 17:04
(0032034)
Utkarsh Ayachit
2013-12-20 08:26
Topics merged into master:
14286_fix_orientation_widget
(VTK) 14426-huge-png
14464_fix_specular_highlights
14466_fix_calculator_panel
disable-unified-bindings-by-default
fix-collaboration
fix_parallel_amrconnectivity
gio-cleanup-and-warning-fixes
pvweb-enhancements-events-protocols-docs
(0032041)
Paul Edwards
2013-12-20 09:25
Hi Dan,
You are right that it would be confusing and the dialog would need to be updated to accommodate it.
One minor point: the level would have originally been 6 as that is the default in zlib - see Z_DEFAULT_COMPRESSION here: http://www.zlib.net/manual.html. [^]
Regards,
Paul |
(0032049)
Alan Scott
2013-12-24 16:06
Tested local server, both ParaView and pvbatch, master, Linux. |
