MantisBT - ParaView |
View Issue Details |
0014428 | ParaView | (No Category) | public | 2013-11-26 17:45 | 2015-01-11 08:22 |
Reporter | Gena Bug | |
Assigned To | Utkarsh Ayachit | |
Status | closed | Resolution | fixed | |
Product Version | | |
Target Version | | Fixed in Version | 4.1 | |
Project | TBD |
Topic Name | 14428_expand_valid_range |
Type | usability |
Summary | 0014428: bad scaling of low values data ranges in 4.1.0rc1 |
Description | Hi!
Found another difference between 4.0.1 and 4.1.0rc1: the last doesn't respect data ranges with upper bound less than 1e-5 when coloring the data. I attached an example that demonstrate the problem: it's a 1D mesh with 100 hexahedral cells: half region has rho = 1e-11 and another half has rho = 5e-6. If you open file in 4.1.0rc1 then color map will be from 1e-11 to 1e-5 (not 5e-5), rescaling doesn't help. In 4.0.1 all works fine.
Env: both 4.0.1 and 4.1.0rc1 were downloaded from the site and installed on Debian testing amd64 |
Steps To Reproduce | |
Additional Information | |
Tags | No tags attached. |
Attached Files | example.vtu (12,501) 2013-11-26 17:45 https://www.vtk.org/Bug/file/9560/example.vtu |
2013-11-26 17:45 | Gena Bug | New Issue | |
2013-11-26 17:45 | Gena Bug | File Added: example.vtu | |
2013-11-27 14:14 | Utkarsh Ayachit | Topic Name | => 14428_expand_valid_range |
2013-11-27 14:14 | Utkarsh Ayachit | Note Added: 0031882 | |
2013-11-27 14:14 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
2013-11-27 14:14 | Utkarsh Ayachit | Fixed in Version | => git-next |
2013-11-27 14:14 | Utkarsh Ayachit | Resolution | open => fixed |
2013-11-27 14:14 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2013-12-04 11:56 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2013-12-04 11:56 | Utkarsh Ayachit | Note Added: 0031897 | |
2013-12-17 21:06 | Alan Scott | Note Added: 0032000 | |
2013-12-17 21:06 | Alan Scott | Status | customer review => closed |
2014-01-09 08:47 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
2014-01-11 08:39 | Utkarsh Ayachit | Fixed in Version | git-master => 4.1 |
2015-01-11 08:22 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 62ad2660 |
2015-01-11 08:22 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master f3fe83f4 |
(0031882)
Utkarsh Ayachit
2013-11-27 14:14
commit f3fe83f44733f84d12fdcd69f62a50ba420fabe5
Date: Wed Nov 27 14:13:30 2013 -0500
BUG 0014428: Expand accepted LUT data range.
Expanded the accepted LUT range. The new delta is 1e-16 for rescaling and 1e-10
for rendering the transfer function in the control widget.
Change-Id: I442e90fc8879598e827ed3b82659ef1475ce8655 |
(0031897)
Utkarsh Ayachit
2013-12-04 11:56
Topics merged into master:
14295_search_text
14342-integrate-empty-servers
(VTK) 14350-opacity-interpolate-scalars
14424_fix_copy_paste
export-tensor-glyph
fix-streaming-behavior
fix_SLAC_tools_segfault
improve-selection-inspector
make-sciberquest-module
pv-collaboration-fix
(VTK) pvweb-doc-update
pvweb-fix-start-test-names
pvweb-group-pattern-option
(VTK) pvweb-integrate-test-packages-alternate
(VTK) pvweb-session-manager-url-update
pvwev-select-box-for-viewport-selection
sqtk-cmake-warnings
(VTK) update_vtk_master |
(0032000)
Alan Scott
2013-12-17 21:06
Good bug report. Thanks for reporting. Also, including the test file helped a lot.
Tested master, Linux, remote server. |
