MantisBT - ParaView |
View Issue Details |
0014608 | ParaView | (No Category) | public | 2014-02-26 20:39 | 2016-08-12 09:59 |
Reporter | Alan Scott | |
Assigned To | Sankhesh Jhaveri | |
Status | closed | Resolution | moved | |
Product Version | 4.1 | |
Target Version | | Fixed in Version | | |
Project | Sandia |
Topic Name | |
Type | incorrect functionality |
Summary | 0014608: TextureMaPToPlane doesn't seem to work with slice. |
Description | TextureMapToPlane doesn't work on slices. This should be fixed.
Local server, Linux, 4.1.0.
Wavelet. Apply.
Slice. Z Normal. Apply.
TextureMapToPlane. Apply.
Now, texture by a picture. I used frame 4 of the can.0004.png movie.
You never see a texture appear. This is a bug.
Steps To Reproduce | |
Additional Information | |
Tags | No tags attached. |
Attached Files | |
2014-02-26 20:39 | Alan Scott | New Issue | |
2014-02-27 12:18 | Utkarsh Ayachit | Note Added: 0032428 | |
2014-02-27 12:19 | Utkarsh Ayachit | Note Edited: 0032428 | bug_revision_view_page.php?bugnote_id=32428#r750 |
2014-02-27 12:20 | Utkarsh Ayachit | Note Edited: 0032428 | bug_revision_view_page.php?bugnote_id=32428#r751 |
2014-02-27 12:27 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
2014-02-27 12:27 | Utkarsh Ayachit | Resolution | open => no change required |
2014-02-27 12:27 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2014-02-27 12:27 | Utkarsh Ayachit | Note Added: 0032431 | |
2014-02-27 12:27 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2014-03-03 14:56 | Alan Scott | Note Added: 0032446 | |
2014-03-03 14:56 | Alan Scott | Status | customer review => todo |
2014-03-21 00:03 | Utkarsh Ayachit | Assigned To | Utkarsh Ayachit => Sankhesh Jhaveri |
2016-07-14 21:16 | Alan Scott | Note Added: 0036516 | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038524 | |
2016-08-12 09:59 | Kitware Robot | Status | todo => closed |
2016-08-12 09:59 | Kitware Robot | Resolution | no change required => moved |
(0032428)
Utkarsh Ayachit
2014-02-27 12:18
(edited on: 2014-02-27 12:20) |
To overcome this issue, set coloring mode to "Solid Color". Texture and scalar coloring doesn't work together when coloring by point-data.
You can turn off "Interpolate Scalars Before Mapping" from the properties panel, and then blending of point scalar colors and texture does work again.
(0032431)
Utkarsh Ayachit
2014-02-27 12:27
customer review for feedback. Please reopen if needed. |
(0032446)
Alan Scott
2014-03-03 14:56
Utkarsh and I discussed. From Utkarsh: I think it's reasonable to expect ParaView to turn off "Interpolate Scalars Before Mapping" automatically when the user loads a texture.
(0036516)
Alan Scott
2016-07-14 21:16
(0038524)
Kitware Robot
2016-08-12 09:59
Resolving issue as `moved`.
This issue tracker is no longer used. Further discussion of this issue may take place in the current ParaView Issues page linked in the banner at the top of this page. |
