MantisBT - ParaView |
View Issue Details |
0014615 | ParaView | (No Category) | public | 2014-03-03 15:46 | 2014-11-26 20:56 |
Reporter | Alan Scott | |
Assigned To | David C. Lonie | |
Priority | urgent | Severity | minor | Reproducibility | have not tried |
Status | closed | Resolution | fixed | |
Product Version | git-master | |
Target Version | 4.2 | Fixed in Version | 4.2 | |
Project | Sandia |
Topic Name | 14615-fix-mpi-segfault |
Type | crash |
Summary | 0014615: Volume rendering crashes |
Description | Volume rendering, remote server, now crashes. It may take a bit of work to replicate (Utkarsh couldn't replicate). Here is what I did:
ParaView master. Linux. Remote server. 8 cores. Mesa (software rendered). Edit/ Settings/ Server/ Remote Render Threshold == 0MB. This is a release build.
Open can.exo. All variables on. Apply.
Forward one timestep.
Paint by EQPS.
Change Surface representation to Volume.
Output messages are as follows:
8 of the following:
ERROR: In .../src/ParaView/4.2.0-alpha/ParaView4/VTK/Rendering/VolumeOpenGL/vtkOpenGLProjectedTetrahedraMapper.cxx, line 183
vtkOpenGLProjectedTetrahedraMapper (0x187436b0): The required extensions are not supported.
8 of the following:
ERROR: In .../src/ParaView/4.2.0-alpha/ParaView4/VTK/Rendering/VolumeOpenGL/vtkOpenGLProjectedTetrahedraMapper.cxx, line 268
vtkOpenGLProjectedTetrahedraMapper (0x187436b0): failed at glRenderBufferStorage color 1 OpenGL errors detected
0 : (1280) Invalid enum
8 of the following:
Warning: In .../src/ParaView/4.2.0-alpha/ParaView4/VTK/Rendering/VolumeOpenGL/vtkOpenGLProjectedTetrahedraMapper.cxx, line 309
vtkOpenGLProjectedTetrahedraMapper (0x18023070): Missing FBO support. The algorithm may produce visual artifacts.
We now get an intermittent crash.
Ask me if you want me to get this in a debugger, or try to get a stack trace.
Steps To Reproduce | |
Additional Information | |
Tags | No tags attached. |
Relationships | related to | 0014581 | closed | David C. Lonie | Volume rendering is bad remote rendering |
Attached Files | |
2014-03-03 15:46 | Alan Scott | New Issue | |
2014-03-03 17:23 | Utkarsh Ayachit | Note Added: 0032448 | |
2014-03-03 17:26 | Alan Scott | Note Added: 0032449 | |
2014-03-03 17:27 | Utkarsh Ayachit | Assigned To | => David C. Lonie |
2014-03-03 17:28 | Utkarsh Ayachit | Note Added: 0032451 | |
2014-03-05 13:02 | David C. Lonie | Status | backlog => active development |
2014-03-05 14:39 | David C. Lonie | Note Added: 0032457 | |
2014-03-06 15:46 | David C. Lonie | Note Added: 0032459 | |
2014-03-11 13:20 | David C. Lonie | Topic Name | => 14615-volume-rendering-tet-crash |
2014-03-11 13:20 | David C. Lonie | Status | active development => gatekeeper review |
2014-03-11 13:20 | David C. Lonie | Resolution | open => fixed |
2014-03-20 08:31 | Utkarsh Ayachit | Fixed in Version | => git-master |
2014-03-20 08:32 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2014-03-20 08:32 | Utkarsh Ayachit | Note Added: 0032493 | |
2014-03-20 21:18 | Alan Scott | Note Added: 0032508 | |
2014-03-20 21:18 | Alan Scott | Status | customer review => todo |
2014-03-20 21:20 | Alan Scott | Note Added: 0032509 | |
2014-03-20 21:49 | Alan Scott | Relationship added | related to 0014581 |
2014-03-21 12:41 | David C. Lonie | Note Added: 0032521 | |
2014-03-21 12:42 | David C. Lonie | Status | todo => active development |
2014-03-24 15:34 | David C. Lonie | Topic Name | 14615-volume-rendering-tet-crash => 14615-fix-mpi-segfault |
2014-03-24 15:34 | David C. Lonie | Note Added: 0032533 | |
2014-03-24 15:34 | David C. Lonie | Status | active development => gatekeeper review |
2014-03-24 15:34 | David C. Lonie | Fixed in Version | git-master => git-next |
2014-03-28 11:55 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2014-03-28 11:55 | Utkarsh Ayachit | Note Added: 0032539 | |
2014-04-08 19:07 | Alan Scott | Note Added: 0032555 | |
2014-04-08 19:07 | Alan Scott | Status | customer review => closed |
2014-05-20 07:29 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
2014-06-17 09:22 | Utkarsh Ayachit | Target Version | => 4.2 |
2014-08-29 11:00 | Utkarsh Ayachit | Fixed in Version | git-master => 4.2 |
2014-11-26 20:30 | Erwin | Note Added: 0033851 | |
2014-11-26 20:30 | Erwin | Status | closed => backlog |
2014-11-26 20:30 | Erwin | Resolution | fixed => reopened |
2014-11-26 20:56 | Alan Scott | Note Added: 0033852 | |
2014-11-26 20:56 | Alan Scott | Status | backlog => closed |
2014-11-26 20:56 | Alan Scott | Resolution | reopened => fixed |
(0032448)
Utkarsh Ayachit
2014-03-03 17:23
Alan,
Which mesa version are you using? |
(0032449)
Alan Scott
2014-03-03 17:26
Sorry, should have included that. 7.10.3.
Alan |
(0032451)
Utkarsh Ayachit
2014-03-03 17:28
David,
You'll have to build with Mesa. I believe the problem is stemming from Burlen's changes to vtkOpenGLProjectedTetrahedraMapper. |
(0032457)
David C. Lonie
2014-03-05 14:39
I can reproduce this, I'll start digging around for the cause. |
(0032459)
David C. Lonie
2014-03-06 15:46
The warnings, at least, seem to be caused by Mesa 7.10.3 not supporting GL_ARB_texture_float. I've not been able to reproduce the crash, but updating the logic in the mapper may solve this for you.
Alan, can you test out the VTK patch http://review.source.kitware.com/#/t/4034/ [^] and see if this fixes the crash? It should at least fix the warnings (except for 'Missing FBO support.' -- that one is legit).
Dave |
(0032493)
Utkarsh Ayachit
2014-03-20 08:32
Topics merged in master
(VTK) 14258-remote-polyhedra
14580-top-level-checkbox
14584-frequency-live-view
(VTK) 14614-report-numpy
(VTK) 14615-volume-rendering-tet-crash
animation-movie-compressor-support
(VTK) catalyst-web-interactive-composite
data_template_redefine
(VTK) enable_subclassing_vtkControlPointsItems
ensemble-reader
expand_fragment_integration
fix-variable-referece
fix_qt5_dashboard_failures
(VTK) probe_enhancements
sciberquest-test-timeout
(0032508)
Alan Scott
2014-03-20 21:18
Nope, still crashes. Details:
* With regards to the warning, we get a warning for every process. If I have 4000 processes, that is an unacceptable number of warnings. Please cut it back to 1.
* "Missing FBO support. The algorithm may produce visual artifacts" isn't descriptive. Is it possible to elaborate? What type of FBO support? Be more verbose, but do it only if the build is debug. (Actually, it could be that way, I am not sure.)
* Why are we missing FBO support now, but 4.1.0 worked fine without complaint? PV 4.2.0 must continue to do volume rendering, in parallel, remote server, with Mesa (for instance, 7.*.*)
Last, it still crashes. Did you try replicating on 8 servers? Here is the crash dump (I have a debug build, but the output looks like release..):
(I have cut out 7 of every 8 lines of output, for brevity.)
I will send directly to David and Utkarsh
(0032509)
Alan Scott
2014-03-20 21:20
I forgot - to get to the crash, you need to click in the 3d window. |
(0032521)
David C. Lonie
2014-03-21 12:41
I've managed to reproduce the crash -- it appears a double click triggers it, which triggers a SelectCells operation on the server for the clicked point.
While rendering the geometry to prepare for the pick, the vtkOpenGLProjectedTetrahedraMapper has a NULL input dataset, which ultimately causes the crash. Now to figure out why that is... |
(0032533)
David C. Lonie
2014-03-24 15:34
Patched volume mappers to handle NULL vtkPoints instances gracefully. |
(0032539)
Utkarsh Ayachit
2014-03-28 11:55
Topics merged into master:
14557-color-legend-update
(VTK) 14615-fix-mpi-segfault
14650_check_bounds
catalyst-web
delaunay3d-alpha-bools
pvweb-doc-update
(VTK) vtk_02_20_2014
14632-find-data-query-combobo |
(0032555)
Alan Scott
2014-04-08 19:07
Nice. Tested remote server, Linux, master. |
(0033851)
Erwin
2014-11-26 20:30
Issue still persists on a local Windows 7 X64 desktop. Following the steps for Exercise 2.14 of the tutorial book ParaviewTutorial42 I get the following error:
ERROR: In C:\DBD\pvs-x64\paraview\src\paraview\VTK\Rendering\VolumeOpenGL\vtkOpenGLProjectedTetrahedraMapper.cxx, line 185
vtkOpenGLProjectedTetrahedraMapper (00000000168447A0): The required extensions are not supported.
vtkOpenGLProjectedTetrahedraMapper (000000000B765D40): The required extensions are not supported.
Using Paraview version 4.2.0 64-bit |
(0033852)
Alan Scott
2014-11-26 20:56
Erwin,
There have been a few problems with volume rendering (and Mesa) that have been fixed in the developers tree since ParaView 4.2.0. These fixes will be rolled out in the next few months as ParaView 4.3.0. Further, this bug was for remote server - your bug is local server. Thus, I am closing this bug.
If you think there is a bug in volume rendering, please write up a new bug report. Assuming you are testing local server (Windows, not connecting to a remote server), you could also download a nightly from Kitware, and try that. Further, guessing here - I bet you have older OpenGL drivers that is causing this issue in 4.2.0 (the issue will be masked in 4.3.0). You may want to try updating your graphics drivers.
As always, thanks for reporting bugs! That's one of the wonders of OpenSource - we all get to work together to create a better product. Thank you.
Alan |
