MantisBT - ParaView |
View Issue Details |
0014687 | ParaView | (No Category) | public | 2014-04-11 20:38 | 2014-08-29 11:00 |
Reporter | Alan Scott | |
Assigned To | Cory Quammen | |
Status | closed | Resolution | fixed | |
Product Version | git-master | |
Target Version | 4.2 | Fixed in Version | 4.2 | |
Project | Sandia |
Topic Name | 14679_color_legend_bugs |
Type | incorrect functionality |
Summary | 0014687: color legend - zero is mis-sized |
Description | When the color legend goes from a negative number to a positive number, it crosses zero. If the tick labels on the right side shrink (due to size constraints for the numbers), the 0 does not also shrink - but seems to follow the font size of the min, max and title. This needs to be fixed.
Steps To Reproduce | |
Additional Information | |
Tags | No tags attached. |
Relationships | child of | 0014679 | closed | Cory Quammen | color legend master bug |
Attached Files | colorLegendScreenshot.png (59,856) 2014-04-11 20:39 https://www.vtk.org/Bug/file/9635/colorLegendScreenshot.png
2014-04-11 20:38 | Alan Scott | New Issue | |
2014-04-11 20:38 | Alan Scott | Relationship added | child of 0014679 |
2014-04-11 20:39 | Alan Scott | File Added: colorLegendScreenshot.png | |
2014-04-12 22:07 | Utkarsh Ayachit | Target Version | => 4.2 |
2014-05-12 11:29 | Utkarsh Ayachit | Assigned To | => Cory Quammen |
2014-05-12 22:53 | Cory Quammen | Status | backlog => active development |
2014-05-29 12:42 | Cory Quammen | Topic Name | => 14679_color_legend_bugs |
2014-05-29 12:42 | Cory Quammen | Note Added: 0032682 | |
2014-05-29 12:42 | Cory Quammen | Status | active development => gatekeeper review |
2014-05-29 12:42 | Cory Quammen | Fixed in Version | => git-next |
2014-05-29 12:42 | Cory Quammen | Resolution | open => fixed |
2014-05-30 08:13 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
2014-05-30 08:14 | Utkarsh Ayachit | Note Added: 0032691 | |
2014-05-30 08:14 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2014-05-30 22:05 | Alan Scott | Note Added: 0032701 | |
2014-05-30 22:05 | Alan Scott | Status | customer review => closed |
2014-08-29 11:00 | Utkarsh Ayachit | Fixed in Version | git-master => 4.2 |
(0032682)
Cory Quammen
2014-05-29 12:42
- Create sphere source
- Add calculator to sphere source. Set Result Array Name to X and the expression to coordsX
- Click the Edit Color Map button
- Note the 0 label on the color scale matches the font size for the rest of the labels
- Stretch the color scale by grabbing on it's left "handle" and pulling it to the left. Note that the 0 stays the same size as the other labels.
- Click the "Edit color legend properties" and change the "Text/Annotation Font Properties" so that the size is 10. Again, the 0 label matches the other labels in size. |
(0032691)
Utkarsh Ayachit
2014-05-30 08:14
SUMMARY
Topics merged into master:
14734-GoodDefaultSizeForpqProxyWidgetDialog
cleanup-cmake
fix_assembly_render_view
fix_fragment_large_scale
fix_plugin_loading_order
fix_qt_modules
remove-unused-directory
Topics reverted from next:
14673_fix_follow_data
(0032701)
Alan Scott
2014-05-30 22:05
Tested local server, master, Linux. |
