MantisBT - ParaView | |||||
View Issue Details | |||||
0014855 | ParaView | (No Category) | public | 2014-07-11 04:13 | 2016-08-12 09:59 |
Reporter | Stephane Veys | ||||
Product Version | 4.4 | ||||
Project | TBD | ||||
Topic Name | |||||
Type | crash | ||||
Summary | 0014855: VisItBridge not compiling anymore | ||||
Description | Hi I want to use VisItBridge, so I tried to compile the repository : ParaView-v4.1.0/Examples/Plugins/VisItReader First, during the cmake step, I had the following error : CMake Error at CMakeLists.txt:25 (ADD_VISIT_PLUGIN_READER): Unknown CMake command "ADD_VISIT_PLUGIN_READER". -- Configuring incomplete, errors occurred! So I added set(VisItBridgePlugin_SOURCE_DIR ... set(AVT_DATABASE_SOURCE_DIR ... include(${VisItBridgePlugin_SOURCE_DIR}/CMake/VisItCommon.cmake) in the file ParaView-v4.1.0/Examples/Plugins/VisItReader/CMakeLists.txt Then, by typing "make" I had this error : Linking CXX shared library libVisItReaderExample.so /usr/bin/ld: ne peut trouver -lvtkVisItAVTAlgorithms collect2: erreur: ld a retourné 1 code d'état d'exécution make[2]: *** [libVisItReaderExample.so] Erreur 1 make[1]: *** [CMakeFiles/VisItReaderExample.dir/all] Erreur 2 If I want to succeed I need to remove vtkVisItAVTAlgorithms from TARGET_LINK_LIBRARIES in ParaView-v4.1.0/Examples/Plugins/VisItReader/CMakeLists.txt My questions are : 1/ Is this example obsolete ? Or in other words, do you still work on this ? 2/ If yes, could you fix erros I mentioned ? Like this we will able to compile Examples/Plugins/VisItReader without changing the CMakeLists file by hand Thank you for your answers | ||||
Steps To Reproduce | |||||
Relationships | |||||
Attached Files | |||||
Issue History | |||||
2014-07-11 04:13 | Stephane Veys | New Issue | |||
2014-07-30 13:07 | Utkarsh Ayachit | Assigned To | => Ben Boeckel (Kitware) | ||
2014-07-30 13:07 | Utkarsh Ayachit | Note Added: 0033144 | |||
2015-07-28 08:39 | Christophe Bourcier | Note Added: 0034840 | |||
2015-07-28 08:51 | Utkarsh Ayachit | Assigned To | Ben Boeckel (Kitware) => Utkarsh Ayachit | ||
2015-07-28 08:51 | Utkarsh Ayachit | Status | backlog => todo | ||
2015-07-28 08:51 | Utkarsh Ayachit | Product Version | 4.1 => 4.4 | ||
2016-08-12 09:59 | Kitware Robot | Note Added: 0038595 | |||
2016-08-12 09:59 | Kitware Robot | Status | todo => closed | ||
Notes | |||||
