MantisBT - ParaView | |||||
View Issue Details | |||||
0014987 | ParaView | (No Category) | public | 2014-09-09 02:15 | 2016-08-12 09:59 |
Reporter | Vadim SANDLER | ||||
Assigned To | Tristan Coulange | ||||
Product Version | 4.1 | ||||
Project | ParaViS | ||||
Topic Name | |||||
Summary | 0014987: The presentation automatically updated in case visualization of the 2 fileds with the same names in the different views | ||||
Description | 1) Open attached files file1.vtm and file2.vtm (from the files.tar.gz archive) 2) Display and color first presentation by the "depl___DEPL" data array and "DX" component, show Color Map 3) Split view and create new Render View 4) Display and color second presentation by the "depl___DEPL" data array and "DY" component, in the second view, show Color Map 5) Activate the first view and select first presentation in the pipeline browser 6) Select the "DZ" as a Coloring component. => In the result a both view are updated, but expected updating only a first view. In case if fields have a different names, the automatic update of the second view is not done. The possibility to compare two components of the same field could be useful. | ||||
Steps To Reproduce | |||||
Relationships | |||||
Attached Files | files.tar.gz (1,594,416) 2014-09-09 02:15 https://www.vtk.org/Bug/file/9710/files.tar.gz | ||||
Issue History | |||||
2014-09-09 02:15 | Vadim SANDLER | New Issue | |||
2014-09-09 02:15 | Vadim SANDLER | Assigned To | => Tristan Coulange | ||
2014-09-09 02:15 | Vadim SANDLER | File Added: files.tar.gz | |||
2014-12-17 07:12 | Tristan Coulange | Status | backlog => active development | ||
2014-12-22 13:59 | Utkarsh Ayachit | Note Added: 0033992 | |||
2016-08-12 09:59 | Kitware Robot | Note Added: 0038652 | |||
2016-08-12 09:59 | Kitware Robot | Status | active development => closed | ||
Notes | |||||
