MantisBT - ParaView |
View Issue Details |
0015015 | ParaView | (No Category) | public | 2014-09-29 16:18 | 2016-08-12 09:59 |
Reporter | Ben Boeckel (Kitware) | |
Assigned To | Kitware Robot | |
Status | closed | Resolution | moved | |
Product Version | git-master | |
Target Version | | Fixed in Version | | |
Project | TBD |
Topic Name | |
Type | usability |
Summary | 0015015: Better defaults for format strings for data labels |
Description | Currently, the default string for data labels is "%-#6.3g" which gives gibberish for non-floating point data values. We should have the default string change values based on the type of the input array (*any* user change should keep what the user wants though). Also deserves a "Reset" button to get whatever ParaView thinks the best format string should be. |
Steps To Reproduce | |
Additional Information | |
Tags | No tags attached. |
Relationships | related to | 0015016 | closed | Ben Boeckel (Kitware) | Crashes with data label format string mismatches with input data | parent of | 0015023 | closed | Kitware Robot | point IDs show up as reals instead of ints |
Attached Files | test.vtu (1,132) 2014-09-29 16:18 https://www.vtk.org/Bug/file/9728/test.vtu |
2014-09-29 16:18 | Ben Boeckel (Kitware) | New Issue | |
2014-09-29 16:18 | Ben Boeckel (Kitware) | File Added: test.vtu | |
2014-09-29 16:26 | Ben Boeckel (Kitware) | Relationship added | related to 0015016 |
2014-10-06 05:57 | Joachim Pouderoux | Relationship added | parent of 0015023 |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038664 | |
