MantisBT - ParaView | |||||
View Issue Details | |||||
0015097 | ParaView | (No Category) | public | 2014-10-30 21:19 | 2016-08-12 09:59 |
Reporter | Alan Scott | ||||
Product Version | 4.2 | ||||
Project | Sandia | ||||
Topic Name | |||||
Summary | 0015097: Optionally allow transparency to be turned off in the color legend | ||||
Description | Optionally, allow transparency to be turned off in the color legend for opacity mapping (which is already done for Volume Rendering). Sometimes you really want to see the colors, even if opacity is turned on. Linux, 4.2.0, local server. Wavelet. Surface. RTData. Color map editor. Select Enable opacity mapping for surface. I want the ability to not have the bottom half of the Color Legend be transparent. | ||||
Steps To Reproduce | |||||
Relationships | |||||
Attached Files | |||||
Issue History | |||||
2014-10-30 21:19 | Alan Scott | New Issue | |||
2016-08-12 09:59 | Kitware Robot | Note Added: 0038700 | |||
Notes | |||||
