MantisBT - ParaView |
View Issue Details |
0015173 | ParaView | (No Category) | public | 2014-12-03 11:47 | 2015-12-11 14:54 |
Reporter | Joachim Pouderoux | |
Assigned To | Joachim Pouderoux | |
Status | closed | Resolution | suspended | |
Product Version | git-master | |
Target Version | | Fixed in Version | | |
Project | ParaViS |
Topic Name | 0015173_stereo_toolbar |
Type | feature |
Summary | 0015173: Imp: Add UI control to activate/deactivate 3D stereo and to select the stereo mode |
Description | Currently, 3D view can be changed to stereo mode only at ParaView start-up with the following options:
--stereo:--stereo-type=SplitViewportHorizontal
or by some python code:
GetRenderView().StereoRender=1
GetRenderView().StereoType="SplitViewportHorizontal"
To be more user friendly, we need an icon in the top of 3D views to be able to activate/deactivate 3D stereo and to select which stereo mode to use in a drop-down list. |
Steps To Reproduce | |
Additional Information | |
Tags | No tags attached. |
Attached Files | |
2014-12-03 11:47 | Joachim Pouderoux | New Issue | |
2014-12-03 11:47 | Joachim Pouderoux | Assigned To | => Joachim Pouderoux |
2014-12-03 11:49 | Joachim Pouderoux | Topic Name | => 0015173_stereo_ui_controls |
2014-12-03 13:08 | Joachim Pouderoux | Note Added: 0033893 | |
2014-12-03 13:08 | Joachim Pouderoux | Status | backlog => active development |
2014-12-04 09:14 | Joachim Pouderoux | Note Added: 0033895 | |
2014-12-04 09:15 | Joachim Pouderoux | Note Deleted: 0033893 | |
2014-12-04 09:15 | Joachim Pouderoux | Topic Name | 0015173_stereo_ui_controls => 0015173_stereo_toolbar |
2015-08-26 10:10 | Mathieu Westphal | Note Added: 0035065 | |
2015-08-26 10:10 | Mathieu Westphal | Status | active development => gatekeeper review |
2015-08-26 10:10 | Mathieu Westphal | Resolution | open => fixed |
2015-09-04 05:31 | Mathieu Westphal | Resolution | fixed => suspended |
2015-09-04 05:32 | Mathieu Westphal | Note Added: 0035173 | |
2015-12-11 14:54 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2015-12-11 14:54 | Utkarsh Ayachit | Status | customer review => closed |
(0033895)
Joachim Pouderoux
2014-12-04 09:14
http://review.source.kitware.com/#/c/18243/ [^]
Change I261e1825: Add a new stereo toolbar to enable/configure stereo mode
The toolbar expose a button that allows to enable/disable
stereo and the attached menu let you choose which stereo
mode you want to set to the active view.
Change-Id: I261e1825ca483b21bcd0c79df8b77663067a7677 |
(0035065)
Mathieu Westphal
2015-08-26 10:10
(0035173)
Mathieu Westphal
2015-09-04 05:32
patch v2 cannot be integrated, for it is not working in Client/Server mode:
Failing test
pvserver, 3 ranks, with remote render threshold set to 0.
Check "Stereo Render", change Stereo Mode to "Red/Blue" -- so far so good.
Split view and create another render view. Segfault. |
