MantisBT - ParaView | |||||
View Issue Details | |||||
0015312 | ParaView | (No Category) | public | 2015-02-09 11:02 | 2015-02-19 08:33 |
Reporter | Casey B Goodlett | ||||
Status | closed | Resolution | won't fix | ||
Product Version | |||||
Project | TBD | ||||
Topic Name | |||||
Type | feature | ||||
Summary | 0015312: Programmable filter support for multiple inputs only one of which is time-varying | ||||
Description | I would like to be able to write a programmable filter that has two inputs. One of which is time-varying and the other is static. The use case for this is the time-varying dataset is transformed by information in the static dataset (after matching timestamps). This works if the time-varying dataset is the first input to the programmable filter. However, there is no way to control via the GUI which is the first input. A workaround to set the order exists by using the "Change input" dialog where the order of selection becomes the order of input. | ||||
Steps To Reproduce | |||||
Relationships | |||||
Attached Files | |||||
Issue History | |||||
2015-02-09 11:02 | Casey B Goodlett | New Issue | |||
2015-02-09 11:02 | Casey B Goodlett | Assigned To | => Utkarsh Ayachit | ||
2015-02-19 08:33 | Utkarsh Ayachit | Note Added: 0034260 | |||
2015-02-19 08:33 | Utkarsh Ayachit | Status | backlog => closed | ||
2015-02-19 08:33 | Utkarsh Ayachit | Resolution | open => won't fix |
Notes | |||||
