MantisBT - ParaView | |||||
View Issue Details | |||||
0015362 | ParaView | (No Category) | public | 2015-03-06 10:43 | 2016-08-12 09:59 |
Reporter | Ben Boeckel (Kitware) | ||||
Assigned To | Scott Wittenburg | ||||
Product Version | |||||
Project | TBD | ||||
Topic Name | |||||
Summary | 0015362: Use higher port for web tests | ||||
Description | On my machine, I've been testing some web server stuff lately which uses port 8080. The web tests in ParaView use the same port and fail when they can't get it. Can they use a less common port to do testing so as not to collide with other things running on the machine? | ||||
Steps To Reproduce | |||||
Relationships | |||||
Attached Files | |||||
Issue History | |||||
2015-03-06 10:43 | Ben Boeckel (Kitware) | New Issue | |||
2015-03-06 10:43 | Ben Boeckel (Kitware) | Assigned To | => Scott Wittenburg | ||
2016-08-12 09:59 | Kitware Robot | Note Added: 0038783 | |||
Notes | |||||
