MantisBT - ParaView |
View Issue Details |
0015370 | ParaView | (No Category) | public | 2015-03-11 13:29 | 2016-08-12 09:59 |
Reporter | koch71 | |
Assigned To | Kitware Robot | |
Status | closed | Resolution | moved | |
Product Version | 4.3 | |
Target Version | | Fixed in Version | | |
Project | ParaViS |
Topic Name | |
Type | incorrect functionality |
Summary | 0015370: Single node hot spot in temperature field |
Description | I tried syrthes thermal analysis earlier with version of paraview 3.12 and everything was working. When I started using paraview in version 4.2 or 4.3 I get from the same results file very high peak of temperature (always 4e+22). this peak is allways on node that is on edge of geometry. I attached two files, one with smooth results from praview 3.12 and second from 4.3 with nodal hot spot. |
Steps To Reproduce | |
Additional Information | |
Tags | No tags attached. |
Attached Files | comparison.png (118,533) 2015-03-11 13:29 https://www.vtk.org/Bug/file/19/comparison.png
2015-03-11 13:29 | koch71 | New Issue | |
2015-03-11 13:29 | koch71 | File Added: comparison.png | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038785 | |
