MantisBT - ParaView |
View Issue Details |
0015398 | ParaView | (No Category) | public | 2015-03-26 19:52 | 2015-09-06 12:18 |
Reporter | Alan Scott | |
Assigned To | Utkarsh Ayachit | |
Priority | high | Severity | minor | Reproducibility | have not tried |
Status | closed | Resolution | fixed | |
Product Version | 4.3 | |
Target Version | 4.4 | Fixed in Version | 4.4 | |
Project | Sandia |
Topic Name | |
Type | incorrect functionality |
Summary | 0015398: selection and menus don't work |
Description | We are seeing a bug that is extremely hard to replicate. It shows up in two ways. First, you can't select any cells or points on the surface of the dataset. Second, you can't get the onscreen menu to work. We finally have a dataset to replicate this. Replicate exactly as follows (I bet it replicates on MAC, Windows also):
* 4.3.1, Linux, 8 servers
* Open dataset DoNotRelease-selectionAndMenuBug. (Ask Utkarsh or me for this dataset). Apply.
* Right click on the dataset. Notice that the menu doesn't appear - you only get "Link Camera". Selections of points and cells on the surface also don't work.
* Note - now, split screen horizontal. Spreadsheet. Sort by GlobalNodeId. Note that there are duplicates. Close the spreadsheet view.
* Turn off block 10, apply. Right click dataset. Normal menu has appeared.
* Turn on block 10, apply. Right click dataset. Normal menu still appears!
What I want - either make this so it always works, or fallback give a message what the problem is, and at least allow users to manually fix the issue (for instance, create a manual ParaView created internal GlobalNodeId). Currently, the hack/workaround is confusing and strictly voodoo.
Steps To Reproduce | |
Additional Information | |
Tags | No tags attached. |
Relationships | related to | 0015425 | closed | Utkarsh Ayachit | check/uncheck selected block buttons don't work (again) |
Attached Files | |
2015-03-26 19:52 | Alan Scott | New Issue | |
2015-03-30 09:56 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2015-04-02 16:00 | Alan Scott | Target Version | => 4.4 |
2015-04-02 16:00 | Alan Scott | Description Updated | bug_revision_view_page.php?rev_id=1049#r1049 |
2015-04-06 11:54 | Utkarsh Ayachit | Note Added: 0034336 | |
2015-04-06 13:27 | Utkarsh Ayachit | Note Added: 0034337 | |
2015-04-06 17:39 | Alan Scott | Note Added: 0034339 | |
2015-05-05 15:00 | Alan Scott | Relationship added | related to 0015425 |
2015-05-29 11:42 | Utkarsh Ayachit | Note Added: 0034432 | |
2015-05-29 11:42 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
2015-05-29 11:42 | Utkarsh Ayachit | Fixed in Version | => git-next |
2015-05-29 11:42 | Utkarsh Ayachit | Resolution | open => fixed |
2015-06-02 08:41 | Utkarsh Ayachit | Note Added: 0034436 | |
2015-06-02 08:41 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2015-06-02 08:41 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
2015-06-02 20:53 | Alan Scott | Note Added: 0034449 | |
2015-06-02 20:53 | Alan Scott | Status | customer review => closed |
2015-09-06 12:18 | Utkarsh Ayachit | Fixed in Version | git-master => 4.4 |
(0034336)
Utkarsh Ayachit
2015-04-06 11:54
Evidently, the issue is that surface selection is not working when remote rendering is enabled!! I can reproduce the same issue as follows:
+ paraview + pvserver (8 ranks)
+ Set "Remote Render Threshold" to 0 -- to force remote rendering.
+ Sphere, Apply.
+ Now surface selection will fail! |
(0034337)
Utkarsh Ayachit
2015-04-06 13:27
Things broke since:
commit c1eac93b7942be9f579d0da8b5121d73dc0e1ae4
Author: Ken Martin <ken.martin@kitware.com>
Date: Fri Nov 21 12:07:58 2014 -0500
Improve picking support in OpenGL2
Point association picking was not implemented this patch
adds that in. Also cell picking did not work when the input
contained quads or higher vertex count polygons. To address
these issues the picking process needs to give the mapper an
opporunity to map the index from the frame buffer back into
a point id or cell id. Added amvirtual method in prop to
do that and an implementation in OpenGLActor and
OpenGLPolyDataMapper to properly map gl_PrimativeId in
the correct point or cell id.
Point picking was not tested in VTK so I added a test for
that as well.
Change-Id: If276e80ab3966646dd9f6f95fbc7734c006f000c |
(0034339)
Alan Scott
2015-04-06 17:39
I'm amazed. Yep, that's the bug. I could have sworn that I had tested with rendering threshold set to 0. Anyway, good find. |
(0034432)
Utkarsh Ayachit
2015-05-29 11:42
(0034436)
Utkarsh Ayachit
2015-06-02 08:41
(0034449)
Alan Scott
2015-06-02 20:53
Excellent, this fixes this bug.
Tested remote server, Linux, master. Tested with selectionAndMenuBug, and also the original dataset. |
