MantisBT - ParaView | |||||
View Issue Details | |||||
0015418 | ParaView | (No Category) | public | 2015-04-09 10:50 | 2016-08-12 09:59 |
Reporter | Dan Lipsa | ||||
Product Version | git-master | ||||
Project | TBD | ||||
Topic Name | |||||
Summary | 0015418: Adding an empty selection clears selection | ||||
Description | 1. Open ParaViewData/Data/can.ex2 2. Click on Select Cells On (s) 3. Create a selection (click and drag to specify a rectangle) 4. Click on Select Cells on (s) 5. While pressing CTRL click and drag to specify a different selection. The cells in the new rectangle are added to the selection. 6. Repeat step 5. but specify a rectangle outside the dataset. The empty set should be added to the set of selected cells, so the selection should be unchanged. However, the selection is cleared. | ||||
Steps To Reproduce | |||||
Relationships | |||||
Attached Files | |||||
Issue History | |||||
2015-04-09 10:50 | Dan Lipsa | New Issue | |||
2016-08-12 09:59 | Kitware Robot | Note Added: 0038801 | |||
Notes | |||||
