MantisBT - ParaView | |||||
View Issue Details | |||||
0015591 | ParaView | (No Category) | public | 2015-07-22 13:18 | 2016-08-12 09:59 |
Reporter | Ryan Noraas | ||||
Priority | high | Severity | minor | Reproducibility | have not tried |
Product Version | 4.3 | ||||
Project | TBD | ||||
Topic Name | |||||
Type | crash | ||||
Summary | 0015591: ParaView crashes when trying to visualize Volume Data of a 3D microstructure | ||||
Description | I am using Dream3D software to create a .XDMF file that is read into Paraview. It reads in OK, and for small files, I can visualize surfaces with no problem. Once I click on the Volume elements, it throws the following errors: ERROR: In C:\bbd\b51c3c7f\source-paraview\VTK\Rendering\OpenGL\vtkOpenGLExtensionManager.cxx, line 757 vtkOpenGLExtensionManager (000000000CE5E830): Extension GL_VERSION_1_2 could not be loaded. ERROR: In C:\bbd\b51c3c7f\source-paraview\VTK\Rendering\OpenGL\vtkOpenGLExtensionManager.cxx, line 757 vtkOpenGLExtensionManager (000000000CE5E830): Extension GL_VERSION_1_2 could not be loaded. ERROR: In C:\bbd\b51c3c7f\source-paraview\VTK\Rendering\Volume\vtkGPUVolumeRayCastMapper.cxx, line 336 vtkOpenGLGPUVolumeRayCastMapper (000000001452D690): scalar of type VTK_CHAR is not supported because this type is platform dependent. Use VTK_SIGNED_CHAR or VTK_UNSIGNED_CHAR instead. Usually, after this, the volume elements will be displayed OK. However, for larger files (256 voxels, cubed), when I try to switch to Volume elements, it immediately crashes Paraview. It opens the error message window, but crashes so quickly that it doesn't have time to show me the message. | ||||
Steps To Reproduce | |||||
Relationships | |||||
Attached Files | |||||
Issue History | |||||
2015-07-22 13:18 | Ryan Noraas | New Issue | |||
2016-08-12 09:59 | Kitware Robot | Note Added: 0038846 | |||
Notes | |||||
