MantisBT - ParaView | |||||
View Issue Details | |||||
0015646 | ParaView | (No Category) | public | 2015-08-13 13:08 | 2016-08-12 09:59 |
Reporter | Ken Moreland | ||||
Product Version | 4.3 | ||||
Target Version | 5.1 | Fixed in Version | |||
Project | Sandia | ||||
Topic Name | |||||
Summary | 0015646: Dragging text annotation creates too many undo events | ||||
Description | When you click and drag a text annotation to move it to another part of the screen, it should create a single undo event to restore the annotation to its initial position. Instead, an undo event appears to be created for each mouse event the GUI received. To replicate, do the following. 1. Sources -> Text. Apply. 2. Drag the text annotation to another part of the view far away. 3. Press Undo. The undo should restore the text to its initial position. Instead, it moves it a little bit. Continuing to press Undo moves the text incrementally to its start, but the undo stack probably maxes out before then. | ||||
Steps To Reproduce | |||||
Relationships | |||||
Attached Files | |||||
Issue History | |||||
2015-08-13 13:08 | Ken Moreland | New Issue | |||
2015-08-17 16:18 | Alan Scott | Project | TBD => Sandia | ||
2015-08-17 16:18 | Alan Scott | Target Version | => 4.5 | ||
2015-09-11 16:44 | Utkarsh Ayachit | Target Version | 4.5 => 5.1 | ||
2016-08-12 09:59 | Kitware Robot | Note Added: 0038865 | |||
Notes | |||||
